  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #2086
    Chris,
    Sorry mate I haven't commented for a while just had a catch up. Outstanding work mate.
    AN HI Scottie no need to apolagise as we cant look at everything can we i would never get off the pc an do any modderling but im glad you thought to drop in to see whats happening on the tiger an its getting very complex now so got to do a lot of thinking ahead as ive still got quite a few bits to build but its comin on
    ATB
    CHRIS
    • ozdell
      • Apr 2020
      • 365
      #2087
      Originally posted by boatman
      an now ive got to make up the batch of four floodlights that are fittered midway way on the hanger back [ATTACH=CONFIG]n1145345[/ATTACH]
      Hi Chris looking good, where did you get those lights from, I need two search lights for my ship want them to light up as well, Tony
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #2088
        HI Tony i made them up they are simply 3mm white ultrabright led's fitted into 4mm aluminumum tube an the ends cut off at an angle as thats how the real things are an then the led negative is soldered to the brass box section an a negitive wire goin to the neg main return an a holes drilled through the brass box section for the positive leds wire stem fitted with a very thin shrink rap around the led + wire so it des'nt short out an soldered to the positve wires an then to their resistor's then to the main feed 6v or 12v feeds hows that best i can exsplain it but its a little fiddley to do but with patience it will an has been built an it all works ok
        chris
        • ozdell
          • Apr 2020
          • 365
          #2089
          chris
          Hi Chris, wow that is the same way I make my own signals but use plastic tubing same affect and no shorting out with brass tubing, will take some pics of my signal bridges with working two way signals .
          Take care Tony
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #2090
            Take care Tony
            HI Tony yea good idea for your two signal lights but im lighting up 12 leds here an if i dint use the brass box section for negatives then instead of just 13 wires id have 24 wires which is more complex so brass for the negs is the way to go for me
            chris
            • ozdell
              • Apr 2020
              • 365
              #2091
              chris
              Hi Chris, that is a great idea using the brass tube as negative , something different, I thought of doing that tried the plastic tube and worked out well, leds are difficult to solder, I must dig out m signal bridges . Work is well under away on my layout, depending on rain if I get down to the shed, take care Tony
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #2092
                HI ALL well the last pics i posted was of the flightdeck floodlight bar all bein wired an soldered togeather an yes all the lights worked ok but now for the hard bit of fitting them down onto the hanger roof an wireing them up to get them to work from the main lives in the hull as they are very fragile so gently does it as it dont take much to damage the led's in their mounting an yes they are now fitted neatly on hanger roof an they work ok Click image for larger version
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #2093
                  AN SOME are not yet lined propeberly yet as i will do this at a later date so they all shine down the flight deck
                  chris
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #2094
                    some angle shots an now on the roof there is fited the flightdeck bubble to contrloll landing seakings choppers Click image for larger version
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #2095
                      port side angle shot an god there was a lot of soldering to do on these leds floodlights Click image for larger version
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #2096
                        AN now something else new ive made up an fitted this triangle shaped emergecy steering conn an it also has lights inside an opening W/T doors an both these unit can be lifted off as they have their own plug s an mountings ive yet to fit the binicale when i make one Click image for larger version
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #2097
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #2098
                            AN a full rear hull shot i wish i could put everything on that ive made but i will do soon as i have a m8 comin over to see how far its got on so i will assemble it then an take some pics of what ive made so far an post them hereClick image for larger version
                            • Mini Me
                              • Jun 2018
                              • 10711
                              #2099
                              I'm calling this a ship......."Boatman"! :tongue-out3: :tongue-out2::tongue-out: lighting came out the Dog's and looking forward to seeing all the doo dads loaded on for the photo shoot. Rick H.
                              • BattleshipBob
                                • 6806
                                • Bob
                                • Cardiff
                                #2100
                                Nice comfy chair Chris!!
                                Cannnot fault the skill, hard work and dedication sir!
