  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #2356
    an done ok Click image for larger version
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #2357
      an here again useing a set sqaure to get her starboard side penant NO.s upright
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #2358
        an here again fittin on her starboard side penant NO.s Click image for larger version
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #2359
          an ok Click image for larger version
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #2360
            NEXT up im now in the process of building the ships crane an its been a devil to build as this is not a kit all it is is just spare bits of P/E an some brass angle that it i puchased from Johns shop BUT first a plan pic of what ive got to build Click image for larger version
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #2361
              an my vershion not entirly accurate but will do for me here im goin through the stages of building the cranes jib made a stat on two sides Click image for larger version
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #2362
                a little more done Click image for larger version
ID:	1150347Click image for larger version
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #2363
                  an half built Click image for larger version
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #2364
                    here some other spare bits of P/E TO CUT UP an fit in the jib Click image for larger version
                    • Nicko
                      • Apr 2019
                      • 1455
                      • Nick
                      • East Anglia
                      #2365
                      That crane looks ace Chris! Are you soldering it together?
                      Nick
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #2366
                        an i only fitted on one hindge to see if it was ok but not so i took it off an here an i soldered on two hindges an the other part of the jib Click image for larger version
                        • scottie3158
                          • 14256
                          • Holbeach
                          #2367
                          Chris,
                          Outstanding work mate.
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #2368
                            Nick
                            HI Nick some parts like the hindges I SOLDERED but for most part i C/A it
                            cheers for lookin in
                            chris
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #2369
                              Chris,
                              HI Scotties yea im happy with it but more to do
                              ATB Chris
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #2370
                                an here most of the jib built but i had to fit the wire ropes roller wheels inside the crane jib due to the size as its nr a foot long so i fitted on the hinges so that it can do what you see in the bottom pic so it does'nt get damagded in tranport Click image for larger version
