  • GerryW
    • Feb 2021
    • 1757
    #2386
    Could you put the heavy parts of the crane motor etc. down low, to keep the weight below the waterline?
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #2387
      HI Jerry wont work as the wire ropes would still be connected an right under where the crane mounting is where the big main motor drive battery is as the whole deck with the crane on must lift off so i can put in an remove the big batt before an after sailing but thank you Jerry for that idea but ive only been thinking about this a day or so but it all comes back to the deck must lift off so any motors an such must be fitted in the cranes mounting AS under that section of deck there is the main drive batt an the steam unit an the P'D'B
      thanks for your thoughts on the subject Jerry
      ATB chris
      • GerryW
        • Feb 2021
        • 1757
        #2388
        Thanks for the explanation - bit of a problem with my idea then! :upside:
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #2389
          YEA Jerry im afaid so as i must admit ive got so much that i want to fit in this hull even though its a big hull i think im gonna be pushed for room but i will find out when she s had her water test but thanks for your intrest in tiger an keep thinking please as you may come up with a great idea that i can put into practice
          cheers chris
            • 18958
            Good progress Chris. She looks smart as paint with her numbers on....
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #2391
              Thanks Tim glad you like her as its been a real battle with this hull but now shes in her top coat of paint all ive now for the moment have to worry about sprayin the clear water proffin lauqer an that 4 coats but when it warmer wheather
              cheers for stoppin
              chris
                • 15817
                Hi Christopher
                Superb work and great dedication to the job.
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #2393
                  Originally posted by Jim R
                  Hi Christopher
                  oh many thanks Jim shes getting there
                  cheers chris
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #2394
                    HI CHAPS well im thnkin of leaveing the ships crane for a bit to see what i can come up with as regards a workin crane but the most important thing at the moment as summer is comin( hopefully) an thats to get her ready for her water tests so ive been concentrating on fitting all 6 stabilizer's an the rudder an the bowthruster an here are some pics but first i removed the maskin tape from her lovely stainless steel prop sharfts Click image for larger version
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #2395
                      next i thought that id strengthen the hull jiont on both hulls as there will be a lot of pressure to this area when liftin her into the water but my boaty m8 say i over enggineer my models but better safe an strong than sorry if she breaks in half when lifting an to make her strong ive fitted two L shaped metal anlgeles in her on each hull jiont an one can be seen layin on the bottom of the hull here an then they have been resined in Click image for larger version
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #2396
                        next i fitted in a greased the stabilizers sharfts so they move easy on the front section starboard side an fitted in the hull bolts Click image for larger version
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #2397
                          an port side
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #2398
                            an then while i was in the bow section i fitted the bowthruster motor Click image for larger version
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #2399
                              an here its all painted a nice white to look nice an neat Click image for larger version
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #2400
                                an all 4 stabilizer's fitted an greased up an all tighten up in the stern section on port side an all the port holes have been uncovered from the maskol an they are nice an clear glass Click image for larger version
