  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #2416
    Wow, wow wow!!
    Utterly stunning, Chris!
    HI Neil yea she comin on soon be time to get her bum wet in the test tank then i'll find out just how well ive built her
    ATB CHRIS
    • BattleshipBob
      • 6821
      • Bob
      • Cardiff
      #2417
      Chris
      How will you join the halves together and i assume when not sailing the seven seas it will be kept in 2 pieces
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #2418
        What a stunning build Chris, the amount of detail and effort is truly excellent!!!!
        an to you also Bob cheers if she was a stug she would be eccellent lol
        cheers for lookin in ps but still a lot can go wrong so fingers crossed
        ATB CHRIS
          • 18958
          Looking good Chris, Love the props, they look superb. Paintwork is great as well.
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #2420
            Chris
            Bob m8 if you look at no'3 pic it shows the big bolts that slip through the holes in the rear section an then its pulled togeather by butterfly nuts an all the eletrics will also meet up by them plugs systems an then when finished sailing (thats assumeing she floats ) i just remove the S/S an then i just undo the butterfly nuts an remove them then gently pull the two halfs apart an then yes Bob you are right she will be standing in the livin room in her cradles stands in two bits till time for sailing again
            hows that ?
            chris
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #2421
              AN HELLO Tim yea she lookin her best now in her full warpaint an with the props on as when she will soon be in the test tank i will need everything on her to find out all the information that i need as she will have pressure test an anti roll tests an a shake tests if she passes them then she will be free then to have all her eletrictrics added in her hull so still a lot more to do before as Bob says sailing the seven seas lol
              ATB CHRIS
              • GerryW
                • Feb 2021
                • 1757
                #2422
                Lovely work there, just loving the look of her.
                • Lee Drennen
                  • 7711
                  #2423
                  Chris. Looking very good getting closer to the finish I see.
                  • Mini Me
                    • Jun 2018
                    • 10711
                    #2424
                    Hi Chris, will you be posting pics of all the different tests and when are you starting? Rick H.
                      This is too much, how did the test go ? Hopefully it went with out a hitch. Even if it did that's not a problem for you Chris.
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #2426
                        HI Gerry yea she's lookin good an im pleased with her but just got to hope she's built as good as she looks but i will find out soon in the test tank
                        cheers for lookin in on the build
                        chris
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #2427
                          AN HI Lee yes she's lookin a proper lady in her warpaint an yea a step closer to the finish but that still yrs away im afraid as all the eletrics have got to be all thought out an fitted on what does what an how thats provided she pass'es her water tests
                          ATB chris
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #2428
                            HI Rick yes i'll post pics of her different water tests but at the moment i just have some paint an a quick lauqer touch up today on the hull jionts an when will i start the tests well thats up to mr wheather as the test tank is out side as to big to be inside i'll post a pic or two of it an then you will see what i mean
                            ATB cheers chris
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #2429
                              AN HI John youre getting a little ahead of me as i havnt done the water tests yet as it out side an the bloomin wheather is raining off an on to do these tests i will need a couple of nice sunny warm days as i will have to baby sit her for the first 3hrs when she is in the test tank as she will be heavly loaded with big batts to push her down above her water line an then hence the water pressure an then to look out for leaks when she's under the water pressure test as it may take an hr or so for the water to find a crack or someway into the hull as even our real new Q/E CARRIER had some leaks
                              thanks for your intrest in the build John an lets hope she passes :fearful::fearful:
                              chris ps IF she does leak i think it will be in the props sharfts glands or around that area
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #2430
                                AN here is the test tank its a 9ft cattle trough that a freind gave me as he could not manage to lift it after me testing my nimitz in it as he had a heart op so had to be carefull an here nimitz in under this pressure test an one tiny small leak which was soon fixed an she then passed my tests with ease Click image for larger version
Name:	carrier build140.jpg
