  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #2536
    AN Here they are both types of motors fitted in the hull an you can see the diffence in size an plus the new top motor has cooling fans fitted in them thats why they are longer Click image for larger version
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #2537
      here all the the new motors are fitted in an ive ran them up to about half throttle power an now there are no problems with comin apart so i think i can tick that off the to do list an ive been useing the old 40 meg R/C to test them as i cant run them useing the new E.S.C.'s till they are all wired up an thats gonna take a bit of thought Click image for larger version
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #2538
        Now talking about the new E.S.C.'s (electronic speed controll ) units an acceroies this in the pic is what ive got to fit in to power the motors Click image for larger version
        • Mark1
          • Apr 2021
          • 4156
          #2539
          Looks like fun, I can manage a plug !!
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #2540
            an in this pic is the wirein diagram an now for a few days will have to get my head around it as this is that BECC system that caused me so much trouble before in the build an as ive never wired up this system before so Click image for larger version
ID:	1155123 well i think im gonna take it slow a little at a time an it will gradully come togeather so it all works phew
            chris
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #2541
              YEA so can i mark but fittin all this in is gonna be a challange
              cheers for havin a look in
              chris
              • Mark1
                • Apr 2021
                • 4156
                #2542
                At least you got a plan! A challenge is what the satisfaction comes from when you get it right:thumb2:
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #2543
                  YEA Mark but fitting two lots in to work four motors an getting it right is the problem as even with inline fuses fitted if i get something wrong it can do damage an in this wireing layout i want to make it so there will be a knock on switch for on off so from THE R/C hand set i can make it so that just two motors work or all four so when running on just two motors i hopefully will get twice the running time but will see on that
                  chris
                  • Mark1
                    • Apr 2021
                    • 4156
                    #2544
                    chris
                    Come again!:anguished::upside::thinking:
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #2545
                      What do you mean Mark ? on the come again ?
                      chris
                      • Mark1
                        • Apr 2021
                        • 4156
                        #2546
                        chris
                        What I mean is i must of ducked because that went right over my head lol, like I said a plugs about it for me :smiling:
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #2547
                          WELL Mark OK i'll keep it simple there will be FOUR motors an TWO speed controlers an each one will work two motors there will be KNOCK on switch fitted on the back set of motors so when tiger is sailing i can just togle a switch on my R/C hand set an the knock on switch will cut power to the back set of motors so that then only the motors near the stern will work so it only be drawin half power but if the wind gets up an the water get choppy then i just send a signal from my R/C HAND SET to reactivate the knock on switch to on an it will then have all four motors goin CLEAR on that ? BUT THATS IF I CAN DO IT but will find out in the next few days when this is all wired up
                          chris
                          • Mark1
                            • Apr 2021
                            • 4156
                            #2548
                            Yeah I get it, from what I've seen so far Chris I have no doubt in your ability to make it work :thumb2:
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #2549
                              OK Mark lets hope your confidence in my ability is not misplaced lol an thanks for your intrest
                              chris
                              • monica
                                • Oct 2013
                                • 15169
                                #2550
                                thats a lot to sort out i feel so glad that you have a plan to make all this work,wishing you luck,
