  • Mini Me
    • Jun 2018
    • 10711
    #2551
    Chris, just caught up to this again...........some real good progress and I like your choice of batteries .....safety first Sir. I hope the wiring is going according to plan and you get the results you are looking for. The two and four motor option is an excellent idea and I hope it works out for you. Keep us posted. Rick H.
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #2552
      Originally posted by monica
      thats a lot to sort out i feel so glad that you have a plan to make all this work,wishing you luck,
      HI Moni yea it is a tad complex but i think that if i think the wireing up in my head an think ahead an take it slow i should be ok but the hard part is getting it all wired in the hull as space is at a premeuim even though its a big hull but fingers crossed i will get it done an thank you Moni for your good luck wishes as i think im gonna need them cheers for lookin in on the build :thumb2: an hope you are ok
      chris
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #2553
        AN HI Rick nice to see you here an yes i was makin good progress on the build untill them bloomin motors let me down but my fault should have checked them propberly before packin them away an exspensive mistake as if i had noticed this short drive sharft i would have sent the motors back an either got my money back or better motors so ive now got to take it on the chin as now too late to return them but at least now i can put this problem right by these new motors as they run great an no probs when on tests so far
        an yes got to be carefull with them batts as they can exsplode if they get to hot but it would have to be over 50 deggrees -C an that kind of heat dont happen here but i like to be on the safe side as i dont want to blow anyone includein myself up an thats part of the reason why i have so many cooling fan fitted in her
        an regards the wirein Rick at the moment i havnt got a clue untill i think this all through an yes i know ive got the wirein diagram but that was just for a test set up which my boaty m8 richard helped me with an yes it all worked ok
        but when fitting it in the ship hull it will take other things as well like ive got to wire in the switches as there will be two an there will be a relay wired in to the circut system an the inline fuse box as this system is gonna take a lot of power up to maybe 30 to 40 amp an ive got to cut off an resolder them ole ripmax plastic plugs as they wont carry this kind of power all they will do is weld them selves together as had this happen on my nimitz so ive got to solder on them yellow 22carat gold plugs as they will carry the power ok an also ive got to do the same for the bow thruster motor SO a lot to think about just got to hope i dont get like PaulE with a MOJO BURNOUT LOL
        AN CHEERS FOR LOOKIN IN Rick an i will report in on whatever way things go on this ATB
        chris
          • 15743
          Hi Chris
          It all looks brilliant. I wouldn't know where to start, it all looks mighty complicated. Glad the new motors fit nicely and work well.
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #2555
            Originally posted by Jim R
            Hi Chris
            G/M Jim yes im havin trouble getting started as well but she lookin good an im pleased at how things are goin as them new motors make all the differnce but wireing them in is gonna be the hard part an as you say looks mighty complicated.an it is as today im just goin to lay out all the components an do some tests by layin them in the hull
            to see if an how things have got to fit in but i know where i will start as been havin a good think through an that the ESC will be as near the motors as possible an ive got to try an keep the wirein as short as possible an try to watch how many jions in the wires i have as they cause resistant to eletric flow
            but i will have to have the gold plugs all fitted in in case i need to remove any part for any reason but im thinkin of doin this in reverse order from the motors outwards right back too ESC's an then inline fuses box an then to the relay an then up to the switches an then back to the batts
            BUT all these will have to have them gold plugs fitted so it looks like im gonna be doin plenty of soldering today an for quite a few days until im back to the main battery wow i feel pooped already just thinking about it AN THANK YOU jIM FOR YOUR INTREST
            CHRIS
            • sootysue
              • Apr 2019
              • 296
              #2556
              Originally posted by boatman
              an in this pic is the wirein diagram an now for a few days will have to get my head around it as this is that BECC system that caused me so much trouble before in the build an as ive never wired up this system before so [ATTACH=CONFIG]n1155123[/ATTACH] well i think im gonna take it slow a little at a time an it will gradully come togeather so it all works phew
              chris
              well Chris . You have totally lost me with this :thinking: wiring?. I,m glad you know, what you are doing Chris:thumb2::thumb2::smiling2:. .It will work out just fine.:thumb2: ...... sue
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #2557
                HI SUE hope you are well an you say you are totally lost on this wirein well at the moment that makes two of us as i only have a vauge idea of what to an how to wire this all up as i was sayin to Jim in thread above its just gonna take some serious thinking an trails an error to find out how the best postion for everything to fit in the hull so its gonna be quite a few exsperiments till i hit upon the right postion for every thing to fit an loads of soldering so this will keep me busy for months
                TAKE CARE Sue till jen an i next meet up with you an thank you from us for the lovely tea an cakes an such you layed out as we really enjoyed our evening with you but it all went to quick like it usualy does THANK YOU
                chris an jen PS keep layin them bricks an you will get there lol
                • sootysue
                  • Apr 2019
                  • 296
                  #2558
                  H
                  I will keep laying the bricks Chris. It's always lovely to see you both Chris and jen you both are welcome over any time big hugs to you both. . I will put less jam in the cake next time it was a bit sweet. . I've just realised that I've still got to do the figures from the last build yet opps. Anyway I know you will figure out how to put in the wiring in your boat Chris just do a little bit each day. Happy building ️..... Sue
                  • JR
                    • May 2015
                    • 18273
                    #2559
                    Did I just read EXPLODE, count me in please.:nerd:
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #2560
                      H
                      OH Cheers Sue yes we throughly enjoyed our evening with you as you are a very easy person to talk to an with an easy goin an if you want a hand to get the fridge an frezzer just txt me an we will come an get you an take you there for you to have a look an if you dont like anything thats there no problem
                      take care stay safe ps wirein got put back a bit as some certain moggie thought she lay all over my bench an when i tried to move her she lightly bit me as a warning to leave her be so had to wait till she got fed up an thank goodness jen came to the recuse by callin SNOWBALL sayin food up then i dint see her for dust lol
                      chris an jen
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #2561
                        AN Here the little devil is blockin my bench lol an when i got the wirein out she wanted to play with it so a bit of a job to get started but i did some wirein in the end GOT the first ESC in place Click image for larger version
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #2562
                          • BattleshipBob
                            • 6803
                            • Bob
                            • Cardiff
                            #2563
                            Did advise you, big stick works lol
                            Or a big fuss
                            I often give my moggies a good old hiding, murky night here not one moggie out working:sad:
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #2564
                              Calm down Calm down John dont get all excited as there will be no exsploshion or we will have to get MATRON onto you an you dont want that do you lol :tongue-out3: :smiling::smiling3::smiling3:
                              chris
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #2565
                                Or a big fuss
                                I CAN tell you bob m8 SHE MAY LOOK CUTE IN PICS BUT im not takein her on as its like W/W 3 AN SHE CAN MAKE A MESS OF ME with them teeth an claws BOY OH BOY an i aint takin any chances an when we trim her nails i have to get all the big heavy rubber gloves on an a hard plastic apron as she fights like heck an i darent hold her to tight for fear of hurtin her but jen trys to keep her calm by talkin to her but me im in the firein line lol
