  • Mini Me
    • Jun 2018
    • 10711
    #2701
    Good on you Chris.......hope to see the wet stuff soon. Rick H.
    • Nicko
      • Apr 2019
      • 1423
      • Nick
      • East Anglia
      #2702
      That's a lot of man-hours gone into all those scratch parts Chris. Amazing work!
      Nick
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #2703
        Rick which wet stuff are you on about the wet paint or the wet water ? lol
        chris
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #2704
          Nick
          AN HI Nick yes there is i was amazed at how much ive built an as you say how many man hrs that have gone into them all but theres still a lot more to build an paint when ive eventualy built them but hopefully these will be all grey in a few days time in primer
          ATB CHRIS
          • Mini Me
            • Jun 2018
            • 10711
            #2705
            Hi Chris, it's always about paint......that is unless you paint with water! LOL Rick H.
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #2706
              YOU B*gger you Rick you had me :thinking: :rolling::smiling3: there an could try pinting with water lol:flushed::nerd::confounded:
              chris the water painter
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #2707
                So Chris....you're telling me it's gonna take you two years to get around to painting this Tiger?? Methinks you misunderstood my reference to the "wet" stuff........Thought you were painting the superstructure cause the weather was turning warmer.....guess I'm a little confused here. Rick H.
                SORRY Rick i did misunderstood your reference to wet stuff bein painting here you said it an i dint pick up on it im begining to think poor Simon T was right about me that he thought i was delixic as i missed out words an miss read a post looks like he was right i'l have to double check what im reading an writeing in future
                chris
                • JR
                  • May 2015
                  • 18273
                  #2708
                  Originally posted by boatman
                  HI GUYS well SUCSESS at last ive been on this eletronics problem now nr 3 wks an this morn with a bit of help from a gent on mayhem ive fineally got all 4 motors running with out them cutting out an i ran them for about 15 mins at about half throttle an the new no'3 motor only got a bit warm like the others so as ive fitted some fans in in the rear funnell S/S it should now be ok but what i found causeing the trouble was a bad heavy duty switch as it had a lose connection inside the switch
                  which was not apparent at the time i checked it so another switch to fit an ive wired it up differnt to the destruckions an now ive had to remove the 2 red wires that fed the BECC so in realaitly ive done away with it an now the R/X is bein fed power from the main batt 12v but with a voltage reducer down to 6v an it all worked great from my new R/C an i can still cut power to the front
                  motors an run only on the rear ones if i want at the flick of a switch on my T/X
                  SO starting tomorrow i can start to wire it all in properly an then when its done then i can get on with the build HOORAY
                  Chris
                  Great news Chris, really pleased for you. That's a great weight of your mind. Hope you've not been grumpy with Jen :smiling3:
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #2709
                    THANKS John m8 an yes it is as i was getting a bit frustrated with problem after problem an yes i admit i was a bit short with jen at times but she knew i wasnt angry at her just the motors problem an jen kept sayin to me you will get it sorted but with her help an a gent on mayhem an you guys pullin for me that helped me get through an its all greatly apprecaited thanks all an im now really pleased that im now back on track but now im up to the painting side of the build yahoo thanks for all you guys lookin in im really thankfull to you all ATB
                    chris
                      • 18271
                      You're going to need a lot of pots of Humbrol for that lot mate!
                      • scottie3158
                        • 14221
                        • Holbeach
                        #2711
                        Chris,
                        When I saw all the superstructure and fittings laid out it made it clear how much skill and time has gone into this superb build.
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #2712
                          HI Ian yes there are quite a few bits an some quite big but there is still more to come an be built an sprayed but im usein the rattle cans so they will spray nr all the bits as ive so far have sprayed all but the two biggest bits an im doin that tonight after tiffen lol
                          ATB Chris
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #2713
                            Chris,
                            AN HELLO Scottie yes i was shocked when i put them all out an there is still more got to be built as its quite a large model but it will be all worth it when she's sailing on the pond an im not only goin to take pics but im goin to video her makin knots as well but the main thing is im enjoyin the build now again
                            cheers for lookin in
                            ATB CHRIS
                            • outrunner
                              • Apr 2019
                              • 2420
                              #2714
                              Boy that's a lot of work Chris, that ship will look the dog's when it's finished.
                              Andy.
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #2715
                                Andy.
                                HI Andy yes IF I REMEMBER RIGHTLY SHE'S ALREADY BEEN AWARDED THE DOGS award an it is a lot of work as its taken me all today to spray all the bits up in grey primer now ive got to inspect every part for cracks or tiny gaps in the builds so i can use some filler to fill them as there are a few as when in white plasti card the gaps cant be seen but when ive sprayed them in grey primer they now show up so tomorrow a day of filling an sanding down smooth an then resprayin all the bits an when im happy with them all then they will all be sprayed in humbroll matt light gray no 64 phew boy will i be glad when ive got them all sprayed up an got to be very carefull spraying as i dont want paint runs an cheers Andy havin a look see glad you find it intresting
                                ATB CHRIS
