  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #2821
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #2822
      • Mark1
        • Apr 2021
        • 4156
        #2823
        Excellent stuff,really taking shape now. :thumb2:
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #2824
          YES she is Mark but ive now tomorrow got to try an get these bridges done an i will have to have good think an plan how i want these to light up an an spraying an then fitting windows glazeing an window wipers
          chris
          • Mark1
            • Apr 2021
            • 4156
            #2825
            chris
            Piece of cake for a man of your talent :thumb2:
            • outrunner
              • Apr 2019
              • 2420
              #2826
              That is going to be one good looker when it's all done.
              Andy.
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #2827
                HI Mark i wish i had your confidence in me that you have got in me id build it with my eyes shut but no im not confident but i gota try an see how it goes an i will plan ahead for pro's an con's on them bridges
                but cheers for your confidence in me very nice of you thank you
                ATB Chris
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #2828
                  Andy.
                  AN THANKS Andy yes she is looking good an sleek i cant wait till i can jion it togeather but still a lot to do before that can happen
                  cheers for stopppin
                  chris
                  • adt70hk
                    • Sep 2019
                    • 10433
                    #2829
                    Chris,
                    Yet again great to see her coming on.
                    Out of interest I was wondering how you move her around I've finished? Given her length. I can only sunny m assume it will be in two halves? If so how will you keep the two halves together in the water?
                    Will you take the deck and superstructure off and screw/clamp them together internally to keep it watertight?
                    Thanks again for sharing your progress.
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #2830
                      Originally posted by adt70hk
                      Chris,
                      HI Andrew yes both main S/S are removeable as this is where the main power batts are an there will be two X 12v 12 amphr batts one in the front section under the main bridge S/S that will power the R/C R/X an all the servos on 6v via a drop down power reducer unit an all the lights an such
                      AN in the rear section another of the same batt that will power all four motors an yes the ship hull has four big bolts on the front hull jiont section an on the rear hull jiont section there are four holes for the bolts to slide through into the rear section an then its a simple method on just fitting on the bolts butterfly nuts that will pull both hulls togeather an water tight an all the eletrics will also meet up in the hull jiont so is it clear how its done ? an thank you Andrew for your questions as its nice to see you guys take an intrest in how the ship will complete togeather an i will fit on a couple of pics how my HMS NORFOLK hulls goes together an then you will understand better i think
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #2831
                        An the rear section where the bolts go through to make it W/T also the eletric plugs to carry elertic through to the rear of the hull hows that
                        chrisClick image for larger version
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #2832
                          AN how she will be moved around is easy both hulls sections will be sitting in there own carry cradles like here with my HMS NORFOLK FRONT Click image for larger version
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #2833
                            AN REAR SECTION sorry pics not too good but had a crap camera
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #2834
                              An the complete ship on the water to show it dont sink lol
                              chris Click image for larger version
                              • BattleshipBob
                                • 6806
                                • Bob
                                • Cardiff
                                #2835
                                Lovely Chris, luv the carry frame !!
                                Always amazed by your work and they float as well
