Excellent Chris, going the extra with the consoles and lighting will set it off a treat.
chrisComment
ATB chrisComment
AN HI Moni yes it is turning into a bit of an epic is'nt it what with the leds now bein fitted in but a lot more still to be fitted an im worryied about fitting this bridge glass in as when gluein it i will have only one try to get it right an if i get it wrong it will be a disarter as the bridge area is on a ship the most looked at area ive found when its bein veiwed by the general public in shows so finger crossed an i will have to have a few practice trys on fitting this glass in
ATB to you an thanks for lookin in on the build Moni as im pleased you are intrested in it
chrisComment
chris
SteveComment
but now ive found that when i fit the glass in due to the lip the glass will not be a tight fit an snug against the window bars its only about a half a mm but still will be a gap so ive had to go inside the bridges an try an file the lips down an then sand them smooth an now i think ive done it thank goodness as i will be fittin in the glass in the next few days but a few trail fits first
cheers for lookin in
ATB chrisComment
HI Tim yes im pleased with that bridge an how its turned out just got to hope the glass will fit ok an i get no glue smuges as i was thinking of usein that clear glue to fix the glass in but i dont think it will be any good as when it gets damp or wet which it may then the glue lose adheshion an goes all white so no good as i found this out when i was trying to fit glass in my first lot of portholes for the hull an i left the glue to dry for a few days an then splashed water on them like they would get when sailing an then the glass fell out an glue went white so i had to then buy the more exspensive brass ones but a better class of portholes which ive fitted in an these are water proff just goes to show that not every idea works out an thank you for havin a look at the build
ATB ChrisComment
