  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #3016
    AN HERE the deck mountings in the hull as just had lots of pva glue all squitred in where it will be glued in hull an when the pva goes off hard its like a glass hard finish so no leaks Click image for larger version
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #3017
      an deck mounting all fitted in the hull an it fiits like a glove an no big gaps Click image for larger version
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #3018
        an deck for now just laid in but later will be all screwed in place so water tight Click image for larger version
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #3019
          an here ive also fitted in a WATER TIGHT BULK HEAD fitted around the stabs pushrods to stop the water from flooding into the hullClick image for larger version
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #3020
            AN SO far im pleased with how the build is comin on apart from that mast eletric pin hiccup.So im now :thinking: what next an planning ahead a bit the only next step in what comes to mind is now to fit in the accessoryies wireing harness all 44 wires so hopefully i'll be able to fit 22 wire on each sides in rear sectiction an front section an now it gets complex so a lot of thinking to do with the ole grey matter will goin into over time lolClick image for larger version
            • scottie3158
              • 14256
              • Holbeach
              #3021
              Outstanding Chris. I really can't wait to see this on the water.
              • Airborne01
                • Mar 2021
                • 4038
                • Steve
                • Essex
                #3022
                Originally posted by boatman
                AN HERE the mast is all repaired an put back together but buy gum i was shattered as it took from 10am till 7pm to sort it so 9 hrs worth of the screamin memmeies lol an jen was also bloomin tired [ATTACH=CONFIG]n1161492[/ATTACH]
                That is a worthy stand-alone model in its own right mate! Good recovery as well!
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #3023
                  HI Scottie same here but weve got to be patience about 2yrs worth lol
                  ATB to you sir
                  chris
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #3024
                    CHEERS Steve yes im pleased jen an i managed to repair the mast lights but it was a near thing an yes the mast turned out good as a model in its own right but should look good on its emplacement on the ships main S/S
                    ATB thanks for stoppin
                    chris
                    • Nicko
                      • Apr 2019
                      • 1455
                      • Nick
                      • East Anglia
                      #3025
                      HI GUYS a few more build pics an ive finally finished working on the 4 stablizers in the stern section an as can be seen the all the 4 rear stabs are now all linked up to work from the push rods connected to the rudder mounting in the stern
                      [ATTACH=CONFIG]n1161936[/ATTACH]
                      That's a pretty beefy fuse you've got in there Chris. Looks like a 30A - that must be a fair few watts going through the system power-wise.
                      Loving the updates. I think we all need plenty of notice for the maiden voyage so we can all get along and cheer from the bank.....
                      Nick.
                      • Airborne01
                        • Mar 2021
                        • 4038
                        • Steve
                        • Essex
                        #3026
                        chris
                        Good teamwork mate - Jen should take a Bow!
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #3027
                          Nick.
                          HI Nick yes the inline fuse is 30 amps an there are three all told the one that can be seen an two more 30 amp fuses in the glass topped fuse box just to be on the safe side in case of a power surge as the ESC are rated at 40 amps each but to be on the safe side fuses are 10 amps under so they will or should blow in stead of causeing exspensive damage to the eletronics but well spotted Nick nothing up with your eyes then an glad you like these updates on the state of build as its been an still is a long time comin but im getting there an yes it would be nice to see you all at the launching but id hide up in case she sinks lol
                          ATB
                          chris
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #3028
                            YES Steve jen is a good un an if i want help in any way she is always willing to help as she wants to see this ship built an sailing as much as i do as she helps me with sailing my norfolk as she loves to answer the general public qeustions on the ship so she/s my P/A lol
                            ATB to you
                            Chris
                            • Airborne01
                              • Mar 2021
                              • 4038
                              • Steve
                              • Essex
                              #3029
                              ATB to you
                              Chris
                              You are a lucky man mate - treat her well! I may even post a couple of questions to your PA ... !
                                • 15817
                                Hi Chris
                                Absolutely amazing stuff. Really impressive. All those wires - nightmare.
