HI Scottie that's not a daft question an its pleases me to see you takin an intrest in what im tryin to build.Well when its rough wheather on the sea the stabilizers work in effect like an aircraft ailerons when the ship rolls to say the port side the stab's tilt upwards forcein the water under to give the ship lift an the stab on the startbord side is tiled downwards so in effect its forcecing the water over the stab so in effect the stab is tryin to pull the ship downwards so to right the ships roll an the same effect is happening on the other stabilizer but this happen fairly quickly so the ship wont turn an roll over an sink best I can exsplain it an it works the same on a model as remember this model will be sailin in the same scale of water as the real ship thanks for your intrest Scottie
chris
chris
