an what with that colured ribbon wire failing its all got to come out an be scrapped as i thought this would happen as thats why i used the gray wires in the front section as they are stronger but i did the ribbon wire first before i thought this would fail an the reason as ive now found out as ive used ribbion wire in all my ships an no problems but this ribbon wire is a couple of guages too thin. I should have taken more notice of the wire gauge when i ordered it off ebay i think its called an i should have bought some thicker gauge so that was a mistake i dint even know id made untill i started to strip the wires ready to solder
an then noticed it was very thin an only about 4 strands i should have stopped then but well i dint as i wanted to press on with soldering the mini plugs on but as they say we live an learn an i certainly have but its all got too be put right before i do much eles as at the moment i am carrying on with the front section wireing on them cam switches that i know is right an will work the ( nav lights )an (white running leds ) on the mast an (bridge lights) an ( 2mm red A/C lights ) on the mast an by the time ive done these the 44 pin plugs should be here an yes i know you guys an i want to see the guns turrets come to life but im afraid im just not at that stage yet as i need power in all the ship hence all getting the wireing done
ATB Rick an thank you for your suggetions an the guns will get built sometime
ChrisComment
Good luck with the rewire, Chris, I have no doubt you will tame the beast! Your determination and concentration are off the chart!Comment
Hi Chris
The work on Tiger continues to amaze. Know that, whilst you’re not posting any pics, that we do all realise how much work is going on in the background. I do hope you get it all sorted before your operation. And that, once you’ve recovered, you can continue to asound us with this stunning build.
All the best
PaulComment
ATB
chris
chrisComment
cheers
chrisComment
Hi Chris
All the best
Paul
chrisComment
ATB TO YOU
ChrisComment
HI GUYS well just a little up date on doin the wirein well i thought its goin great as ive so far been working in the bow section an wired up the nav lights an the white mast running or steamin light which ever well i was on a roll today only to be again let down by some new plugs an sockests wel i found that after soldering on the wires for the above that when i tried to seperate the plug they just fell apart why must things be made of cr*p nowa days Aaaaaaaacccccchhhhhh
pic below of this new plugComment
