AN now a shot inside the hull to show how the sharfts must line up against the keel as im usein that as a I think its called a datum point an just tryin to work out how the motors will be fitted down as I cannot screw the mountings to the hull or the screws will go through the hull so got to think up summit elesComment
HI Steven yes she is but I must admit i'll be glad when ive got all these prop sharfts glassed in an done as its really testin me but as I said before im enjoying the problems posed an tryin to solve them an hopefully I will thanks for your intrest
chrisComment
HI Ralph its good to see you back on the forum as I wondered that I hadn't seen you on for a few weeks an hope you feel better an glad you feel like lookin up on the build as its getting complicatied now but this is when now it will get intresting with all the bits that have got to go on her but I have so far got everything in hand but I can still see some problems loomin but will deal with them when I get to them many thanks for lookin in Raph :thumb2:
chrisComment
HI GUYS a small update on her
I have been tryin to fit the 4 prop sharfts on her an oh its been a bloomin job as due to the hull curevature its nr impossible to get the measurements right must have taken the sharfts in an out about 20 times. But I think I have mastered it NOW tomorrow im gonna take it all to bits again to trim up the A-FRAMES as got to be carefull I don't cut to much off an I have had to make a mock up cardboard template then transfer it to a wood one as stronger to hold the outer sharfts in placeComment
