  • scottie3158
    • 14256
    • Holbeach
    #331
    Chris,
    You appear to have resolved the fit issues nicely done.
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #332
      close up shot an as can be seen the sharfts are fairly level only a few deggess out which is just right how I want it Click image for larger version
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #333
        Chris,
        CHEERS Scottie yes everything seems to be turning out fine but im not raisein the flags just yet as still a lot can go wrong as until they are all glassed into postion im holding my breath thanks for your nice comment Scottie an intrest
        chris
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #334
          AN one overall pic of it Click image for larger version
          • BattleshipBob
            • 6821
            • Bob
            • Cardiff
            #335
            Very nice Chris, enjoying watching every step:smiling4:
            what celeb is launching the beauty:thumb2:
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #336
              HI Pete are you missin any minions have any gone A.W.O.L as some have escaped your compound an I found them workin on my tiger no wonder the measuments kept comin up wrong they must have been sabotagein it an now if anything goes wrong I can blame them :smiling5::smiling5::smiling5: LOL the missus see some in a shop an bought them as you have hooked her I suppose the house will be took over with them now :cold-sweat:
              chrisClick image for larger version
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #337
                HI Bob glad you enjoyin the build an what celeb proberly the little buggers in the above pic lol as the have been up to a lot of mischief lol Pete will have to bring matron with the big needle to sort them out lol
                • flyjoe180
                  • Jan 2012
                  • 12480
                  • Joe
                  • Earth
                  #338
                  Prop shaft pointing downwards = speedboat?
                  Great work continues
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #339
                    HI Joe cheers for your great work continues comment :thumb2: an i'll see that it does if I can get rid of those pesky minions LOL:smiling3: . An yes the prop sharfts are pointing downwards slighty as its due to the prop sharft length as they have all got to meet up to the motor centre spindle as if the sharfts were any longer to level the sharfts flater the outer motors would be in the battery bay an that's no good so this is the final design of the sharft alignment an its correct with the plans so onwards an upwards.But firstly today I have got remove all the prop sharfts an motors so that I can refine an sand down an recut the A-FRAMES to the correct length .Then when done that it all goes back togeather to be glassed in their correct postion's an phew will I be glad when ive done it
                    chris
                      • 18272
                      They dont look to steep but if you are pushed for room you could maybe try a flex coupling by the motors... I see that you have UJ or CV joints at the motor spindle but you could add another a few inches down the shafts to help flatten them. Just an idea.
                      If they match the plan why worry. ;-)
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #341
                        HI Ian thanks for your comments an yes they match the plans within a few degrees so as you say why worry an im not its goin togeather how it is as its taken a lot of workin out to get it how it is. It would have been better if I had a cambelt drives but I cant get them now as they were made by a company called MFA an they don't make them any more so gotta use what I can get
                        chris
                        • Neil Merryweather
                          • Dec 2018
                          • 5208
                          • London
                          #342
                          HI Chris ,
                          I am in total AWE of what you are attempting- never mind achieving!
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #343
                            HI Chris ,
                            HI Neil many thanks for your kind comments an I am glad you like the build an I am in AWE of it also as this ship is the hardest I have ever tried to build it makes my USS Nimitz big aircraft carrier build seem easy as its all the curves on this hull TBH ive never seen such a weird shaped hull as this but I will get it done even if it takes me yyyyyrrrrrsss LOL an thanks for stopping by an your intrest
                            Chris
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #344
                              HI all just thought id post this pic as I forgot I had it in my pc of tigers sister HMS BLAKE C99 an hopefully my tiger should come out lookin nearly as good but not in the bright colours but it tell you a lot about the ship which is quite intresting an I think it looks quite a hansom ship. pic for discussion pupose only
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #345
                                HI ALL another small update on her
                                ive been tryin to fit an glass in all four prop sharfts on her an its been a devil of a job to get right but thankfully ive managed it the prop sharfts splay outward by 2mm each side as had to do this so the motors would fit in the hull an it was a close run thing any les an they would not have fitted in the hull an 1st pic took me ages to mask all the joints up
