  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #3841
    Originally posted by Mini Me
    Looks like you're making progress though...
    HI Rick yea but hard goin as nothin lines up so clamps are order of the day but like you say im getting there but not like Petes s chopper it looks good compered to mine
    chrisb
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #3842
      an so far the lights work but still more to fit on Click image for larger version
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #3843
        an so far both motors are workin an ive painted up the rear rortor blades in their colours an the motors are takin power from their gold pick up pins Click image for larger version
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #3844
          an as this kit is such oop: ive had to get out bigger clamps to close the gaps Click image for larger version
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #3845
            an again it can be seen how bad a fit it is Click image for larger version
              • 18958
              Looks like a bit of a hammer and nails job Chris. Sure youโ€™ll sort it though.
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #3847
                an had to fit some plastic wood filler as i find this good stuff to fill gaps an its hard within 10 mins so it can then be sanded down an again a rotten fit so a lot of filein down to do Click image for larger version
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #3848
                  HAMMER Tim if i had one in me hand it would go down on this rotten fit kit only hope the airfix one is better
                  chrisb
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #3849
                    an now fitting the bottom section an ive just soldered the last lot of wires an ive painted over the positive an negitive wires with makol as its a good insulater as it goes off like rubber an can stop any short outs Click image for larger version
                    • stillp
                      • 8106
                      • Pete
                      • Rugby
                      #3850
                      Is the floor too wide for the fuselage Chris? My Revell one was, at the front.
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #3851
                        an here another rotten fit thats gonna require a lot of filler as at its widest point its nr a 1/8th gap Click image for larger version
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #3852
                          YES IT was Pete but i cut no end off to make sure this dint happen but as i could not fit the bottom propebely till i soledered all the black leds wires as they brake very easy as they are only as thick as human hairs i had to trust to luck an as you can see im not lucky
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #3853
                            an i fitted a hinge to the cockpit door so it will open close as i done this on my merlin but that kit was a whole lot better fit an here its open so the pulic can see inside Click image for larger version
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #3854
                              an closed up Click image for larger version
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #3855
                                starbord side shot an if all the lights work the three crew memember will be seen but ive got to repaint their faces as i was just muckin about drawin on handle bar moustages but forgot to repaint themClick image for larger version
