  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #391
    SO nxt stage I think is cutting out the front deck an its big an bloomin cold in garage glad I was not out there to long Click image for larger version
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #392
      • tr1ckey66
        • Mar 2009
        • 3592
        #393
        Small but important details make all the difference. :thumb2:
        I forgot to ask Chris, where do you construct these (large) models – Garage/shed?
        I‘ve never really had to think about the cold weather affecting when I paint as my builds are small enough (on the whole) to spray indoors in the booth.
        I guess you’ll spend the winter months on the construction of Tiger?
        Paul
        • tr1ckey66
          • Mar 2009
          • 3592
          #394
          Ah, you answered my question in the very next post!!!! :tongue-out2:
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #395
            Here its just laid on the front section to get a little idea of how it will look an compare with the plans to see where the cutouts will be Click image for larger version
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #396
              Paul
              HI Paul yes its gonna be some contruction an the ship has been worked on in the garage in summer an now in my model room but no sprayin im afraid so the deck will do to keep me busy till feebee comes again an proberly some eletrics
              chris
              • tr1ckey66
                • Mar 2009
                • 3592
                #397
                Hi Chris
                Quick question (possibly a stupid one) why do you split the hull/build in sections? Is it simply to make the build more manageable?
                Paul
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #398
                  Hi Chris
                  Quick question (possibly a stupid one) why do you slit the hull/build in sections? Is it simply to make the build more manageable?
                  Paul
                  HI Paul im not sure what you mean when you say slit the hull ?do you mean why have I cut the hull in two bits ?
                  chris
                  • tr1ckey66
                    • Mar 2009
                    • 3592
                    #399
                    chris
                    Exactly
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #400
                      Exactly
                      Well Paul for a start its not a stupid question ive been asked this loads of times as its logical as mr spock would say no.1 the front section will fit in its own carry cradle with handels so it can be carried like a suitcase an that way it wont get broke an the same with the rear section an no.2 it will be lighter to carry over to the pond an no.3 this the only way it will fit in my car as the front section in its cradle will fit in the boot an the rear section will lay in its cradle across the back seat with batts an R/C an chairs fittin in the backseat foot wells hows that paul
                      chris ps NORFOLK is like this also an if something works why change it
                      • tr1ckey66
                        • Mar 2009
                        • 3592
                        #401
                        Thanks Chris for the explanation. As someone who has never built anything quite so large I’m interested in the logistics that go into it. Your magnificent builds demonstrate a system that very much works so no need to change whatsoever! It does raise another question though (and i might be jumping the gun here) but you must have a system for joining the 2 halves so that they’re water tight? You may have explained this in the Norfolk build so I hope I’m not retracing old ground.
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #402
                          HI Paul im very pleased that you are intrested in the build an if you jump back in this build to the near the bottom of page 2 all will be revealed about how the model is made water tight as its the two bulkheads that pull togeather an its joins up the electric plugs. An the hull is pulled togeather by butterfly nuts onto the bolts that go through the brass tubes to stop wear an then tightened up an to release the hull to split it apart just undo the butterfly nuts an remove them an the whole front section slides apart. Hows that for exsplaination an now i'll include a a few of pics of NORFOLK in her carry cradles for you to see how easy it is to carry the model just got to hope it will work out on tiger as she is a lot bigger but please exscuse the piture quality as I had a new camera an could not find out how to turn off the white flash any way the 1st pic the stern section of NORFOLKClick image for larger version
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #403
                            An the bow section an the handles just pull apart an can be unsrewed an taken right off if wanted but I normally just part the handels open an the ship can be lifted out of the cradle an then fitted into her show stand Click image for larger version
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #404
                              An in case you are wondering Paul the carry handles are made up from old fold up easy chairs that have broken over time an ive already got some more chairs layin in my shed all ready to make some more up for tiger but they wont be needed for at least a couple of yrs yet but in this big modelin game you have to think ahead
                              chris
                              • tr1ckey66
                                • Mar 2009
                                • 3592
                                #405
                                Awesome!
                                You see, I think stuff like this is every bit as impressive as the build itself. And yes, thank you for the explanation.
                                I’m definitely onboard (forgive the pun) with this build :tongue-out2:
