  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #4051
    Originally posted by Jim R
    Hi Chris
    Glad to see you posting. Netting looks great. I am sure you'll sort the turret gearing. You have overcome so many issues and always come out on top that I know this will be the same.
    Hello Jim hope you an yours are well wow i wish i had your confidence in me that you seem to have but so far on this turret probs yes i could go for the easy an simple route by just fitting a sqaure plastic tube on top of mt S/W servo an anothe smaller sqaure plastic tube connected to the gun turret an the small one slides into the bigger one on the servo yes i should think that would work but to me it to simple an easy i want to use up the exsensie gears i have bought so yes hopefully i may be able to best this prob but perhaps im my own enmy here but will as you say Jim get it sorted like i have with some others help
    anyway you pushed up my mojo an tomorrow im gonna do more testing on the probs ATB
    Chrisb
      • 15745
      Having seen what you've achieved so far i know "you ain't one to be beaten"
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #4053
        WOW Jim yes i must admit that ive succeed a bit on this ship an yes it comin on an yes i dont like to be beaten an yes i love a challenge but this may be one to far for me as i said i think im my own worst enamy by tryin to hard a things an to complex but i will tinker along an see how thing turn out as i have most of the things i need to make the turrets turn an such as i have a spare servo morph to make the servo turn slowy on that big turret gearing i bought off ebay but also ive got to make it a size that will fit under the gun deck an it must be made to all lift out so i can get to this eletronics below in the hull Click image for larger version
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #4054
          an this lot an this is just below where the main 6inch gun turret is mounted so i cant glue any mountings in the hull its all got to come out if need be Click image for larger version
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #4055
            HI all just a small update today an thats to say ive made a start on makeing them gun turrest turn an below is just what its gonna take to make it happen if i can
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #4056
              an in the pic below the black turret gear ring ( actuall size ) ive cut out only roughly the white base plate that will be gluded to the big black turret gear ring when ive smoothed its edges down with a smooth grinder tool in my dremel an then i must find the centre of the base plate to drill a hole for the gun turret spindle an if i remember rightly there was someone on here who put a thread on how to find the centre of a circle so anyone know where i can find it on this forum
              chrisbClick image for larger version
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #4057
                an the white base plate an the black turret gear ring is under the white base plate an ive laid out some of the big an small gears that i want to use
                chrisb Click image for larger version
                • wotan
                  • May 2018
                  • 1150
                  #4058
                  Looking good Chris. How many channels do you have left to turn and raise and lower the guns?
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #4059
                    HI John well i have two channels left out of 14 cha's but unless i grow a third hand its gonna be awkward too say the least as i want the guns turrets on channel 2 which is a stick on the T/X
                    ( transmitter) an no. 14 channel is a pressure switch on the T/X which means i press it down an it flicks back up again as it spring loaded soon as i let it go but i may be able to get around it by movin some function on the R/X to another channell an get round it that way as it will free up a better switch on the T/X BUT it all will be exspeimental for a week or more till i find out which is the best way an same with the gears that will hopefully work that black turret ring gear that will be connected to the gun turret an cheers for lookin in John hope you are well
                    ATB
                    chrisb
                    • adt70hk
                      • Sep 2019
                      • 10429
                      #4060
                      As ever Chris, write simply mind-blowing! Simply outstanding!
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #4061
                        HI Andrew ta very much yes im pleased with how things are goin if i can just get these gun turrets to work an train to port an starb an elevate i'll be on the home run
                        cheers Andrew
                        chrisb
                        • scottie3158
                          • 14221
                          • Holbeach
                          #4062
                          Chris,
                          Have fun mate.
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #4063
                            Chris,
                            Have fun mate.
                            HI Scottie yes it will be fun an a challange to do what im hopein to do with all these gears but gonna be a bit hit an miss if i cant get the right speed on getting the gun turret to turn slowy an compact enough to fit in under the gun base so it can be lifted out to get to the other eletrics in the hull but im not in any hurry so see how things go an im makin a proper start to day an im a bit miffed that after trying out the sailwinch servo im not getting the 6 revoluions that the makers claim all im getting so far is 4 an a bit so i will have to try an alter that servo morph exstender to its full throw an then see how many i get (phew )
                            ATB
                            chrisb
                            • Andy the Sheep
                              • Apr 2019
                              • 1864
                              • Andrea
                              • North Eastern Italy
                              #4064
                              Chris, I think that the link here should lead to the
                              Finding the middle of a circle thread.
                              Happy modelling and a hug to that lovely white ball of fur.
                              Andrea
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #4065
                                Andrea
                                HI Andrea yes ive already now found that thanks to the guys but to understand it is the problem as im pullin my hair out an nearly bald now lol as im not sure i understand it about the triangle an such an what Gern put on well the ole brain is overloaded lol an yes lilley the cat says meow to you Sir an thanks for the hug lol
                                ATB to you Sir
                                chrisb
