    • 15737
    This just gets more and more amazing with each update. You have incredible skills, knowledge and patience. Glad the turret movements are sorted.
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #4082
      CLOSE UP shot of where the gears meet an they fit like a glove just as well i dint go for the small gearing but im trying to imatate the gearin on the real ships next up to build the gun turttets but fistly the big 6inch turret Click image for larger version
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #4083
        Originally posted by stillp
        Well done Chris!
        Cheers Pete hope you an yours are well
        chrisb
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #4084
          Originally posted by Tworrs
          Great progress Chris, I knew you'd figure it out.
          ATB
          Garry
          AN Thanks Garry took a bit of doin but had fun with them gears an got there in the end
          ATB on I/D
          chrisb
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #4085
            AN Thanks Jim well nearly sorted as had a thought tonight about that steel bolt thats holding it all together an realised that i wont be able to get the wires up to the micro servo that will be in the main gun turret so had a think an yes a brain wave hit me (dont have many of them often lol) but the thought was ok i need a bolt an nut with a hole up the centre to take the servo wire up an yes found up two rudder bolts with holes up where the rudder shaft normally goes so they will do great as the wires will go up to work the micro servo to elevate the guns hope to do this on both gun turrets so probs solved i hope so tommow i will take out the steel bolt an redrill the holes to take the plastic bolts yay this is a problem ive been thinkin on for months
            chrisb
            • Mickc1440
              • 4779
              #4086
              More great work Chris
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #4087
                THANKS Mick m8 but still a lot to do im afraid a ive got too get both turrets working togeather now that will be a feat as im hopeing to have them both working off one channell from the T/X but wheather there will be enough power to work 4 servos altogeather well i dont know if not then ive still one spare channell on the R/X to use but at least ive made a good start on these guns an ive ordered the gunfire sound unit an spk to go with it an it will also work the leds gunfire flashes hopefully but it goin to be fun to wire it all in but im hopein to have this unit working off my waterproff mylar spk an fit in non return diodes so that the power can only go one way an not damage the other unit the whoopper sounds system in the same circut
                chrisb
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #4088
                  Originally posted by GerryW
                  Just had another catch up. Things are progressing nicely.
                  Yes, those turrets are going to be the cause of many headaches for you, to get them self centering, elevating and turning on just the one channel? Glad that you know about these things - all I can think of would be some sort of cam with wiring to bring it back to the middle again (something like what they use for windscreen wipers to return them to the rest position)
                  HI again Gerry well it looks like you can see into the future when you posted this blog as been doin some more exsperimenting on the turret turning an yes it turns great so got that mastered BUT that micro servo that wired into the same channel to raise an lower the guns is causein some probs as when i turn the big gear that turns the main turret the micro servo on one way works fine an mimicks the big servo on how it works but turn it the other way an a prob arises dont know why
                  as at the first trys it went all ok but now im getting servo jump as yes it goes the same way as the big servo but then at the end of travel the micro servo jumps back to oppitsite way why its doin this i dont know
                  but i will have too go onto mayhem ship site an ask some questions in the black art section on electronics an see if anybody can tell me what happening with this servo an it not just this servo as ive treid several different ones an they all do the same thing but i think its something to do with that servo morph estender unit
                  chrisb
                  • Airborne01
                    • Mar 2021
                    • 4001
                    • Steve
                    • Essex
                    #4089
                    Originally posted by boatman
                    an i have fitted on the seaking chopper to see how things look an i think its all ok hope you all do ?[ATTACH=CONFIG]n1177106[/ATTACH]
                    :thumb2:
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #4090
                      :thumb2:
                      HI Steve im glad you like the seaking on the flightdeck an yes im pleased with it turned out just as i hoped it would
                      ATB
                      chrisb
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #4091
                        chrisb
                        well hi guys well ive sorted that servo prob my self thank goodness after a bit of help from others on mayhem an both servos are now working in tandem how i wanted them too so can now press on on the gun turrets
                        chrisb
                        • adt70hk
                          • Sep 2019
                          • 10426
                          #4092
                          Chris
                          As always quite simply brilliant exclamation mark!
                          I really am very glad that you managed to fix the gearing issue, as I can imagine that might have spoilt things with the finished ship.
                          Keep up the great work.
                          • minitnkr
                            Charter Rabble member
                            • 7551
                            • Dayton, OH USA
                            #4093
                            Some really brilliant work Chris.
                              • 18931
                              Excellent news. I know that one’s been niggling you for ages Chris so it must feel great to have nailed it.
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #4095
                                Originally posted by adt70hk
                                Chris
                                HI Andrew yes it would have done cant have a warship that cant turn its gun turrets can we lol
                                cheers for lookin in an have a nice day on sunday with all the rabble lol really nice guys them lot are
                                chrisb
