I might well be wrong, but I'm thinking that a pen spring might be too strong (even compressing, rather than stretching) as they're a fairly strong wire and wound rather 'tight' - you may find that you might have to stretch and cut one to reduce the number of coils to 'soften' itComment
Just had another look Chris. Couldn’t you just replace the flexible link between the servo and the barrels with a wire link? The servo should move the barrels up and down then. If you are worried about the servo being over stressed at the end of the run just put an omega loop like this
In the wire. Don’t buy them, just form it with round pliers. If you use thin nickel silver, or even phospher bronze, wire you will get no problems as it will hold the shape nicely.Comment
cheers for info an your intrest
ATB
Chrisb mtbComment
but cheers for your idea has it has some merit
ATB
CHRISB MBTComment
Hi Chris. The omega doesn’t have to be a loop. We used to use this sort of arrangement for point operating rods in model railways if the area it had to fit in was very tight. The two connection points can almost be touching but you still get deflection in the bent area.
If you size the wire correctly you will get a very positive, but gentle, transmission of movement from the operating system. Still may not do what you want, but probably worth a little experimentation.Comment
The great work continues mate. I have a question if I may. Given that all the deck surfaces are painted green, I would presume to help hide the ship from above why do they not paint the top of the turrets?Comment
cheers for your intrest
ATB
chrisb mtbComment
Hi chris
its been a little while since I checked in and all I can say is; wow! She is certainly coming together.
One question about the colour of deck which you may be able to help me with: what do you think the deck flooring would have been in the ward room of HMS Bulldog in 1945? I ask becasue for many years I have toyed with the idea of a boxed diorama depicting the signing of the German surrender aboard HMS Bulldog in 1945.
PeterComment
Hi chris
Peter
ATB to you an i hope you find out about your question
chrisbComment
cheers
chrisbComment
HI Peter nice to see you on my tiger blog again an hope you have recovered in your health an yes tigers comin on but there is still so much to still build an fit on her but im enjoyin its keepin me sane i think an regards your question regards hms bulldog well im afraid i cant help you there as yes im into ships an such but i only do reseach on the ship im building as yes i look at other ships real an models but thats all i do just look as if i reseached every ship id never have any modelin time if you see my meaning SORRY Peter
chrisb
PeterComment
