  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #31
    Hi Ken glad you are along for the build an Pete yes it is rather fragile at the moment but once the keel gets screwed down on the build board an the hull frames, HULL JIONT, an the quadrons all fitted an glued in place it will be very strong till then I just got to handle the keel with care. An Jim glad you like the build it should get better as it goes an Bob you say say you wont know where to start well its been ten yrs or more since I scratchbuilt Nimitz an im havin a job remembering whats next so im a bit in the dark we see how it goes ( hopefully )
    thanks for your intrest guys
    chris
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #32
      Hi guys some more pics of the next step an that's the hull joint now getting this right is critical as if its out of alignment the eleltric plugs wont line up or fit
      first pic cutting out the H/J 'sClick image for larger version
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #33
        BOTH H/J s cut outClick image for larger version
Name:	IMG_3967 - Copy (2).JPG
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #34
          Well that them cut out now over the nxt few days I will attempt to drill out the four bolt holes that holds the ship togeather an cut an fit the brass sleaves that stop the holes in H/J from wearing every time I fit the ship togeather .Here a couple of pics of how the H/J's should look taken fitted in my HMS NORFOLK F230 FRIGATE when done an fitted with four holding bolts an butterfly nuts for ease of fittin said holdin nuts an there will be
          a male an female 25 pin electric connecktor to carry the power for all the servo's an lights an such but im not sure if I WILL need the big electric plug in tiger as im not sure where the batts will be fitted anyway the pics 1st pic the male H/J an the 2nd pic will be the female H/J Click image for larger version
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #35
            FEMALE H/J Click image for larger version
            • Steven000
              • Aug 2018
              • 2830
              • Steven
              • Belgium
              #36
              Very interesting project Christopher!
              I will follow your build, cheers, Steven
                Like what I'm seeing.
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #38
                  Thanks guys for your intrest an I will be :cold-sweat::cold-sweat: sweating over the nxt few days tryin to get these H/J 's right as it so easy to make a mistake will post some more pics when I have got that far
                  chris
                  • Fernando N
                    • 2448
                    #39
                    Good luck with such a missive build Chris.:astonished:
                    Love the connectors and pins used in your frigate, very smart to keep her transportable.:thumb2:
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #40
                      HI THANKS for the good wishes Fernando glad you like the hull joint idea when ever I exhibit her in a model show I always get people comin up at the end of the show when im splittin her so they can see what the idea is like an how its done an they chat like mad about it but I don't mind it as if it will help one person on their own model doin this then im pleased as that's what modelling all about helpin others
                      chris
                        Think i might have to have another trip to the flatlands to see you lot down there, its been a while, love watching your builds progess Chris
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #42
                          HI Rob be nice to see you an glad you likeing the build hopefully tiger should have a lot more done if you come down
                          • sootysue
                            • Apr 2019
                            • 296
                            #43
                            HI looking good
                            • Peter Gillson
                              • 2594
                              #44
                              Chris
                              I often wondered how peo[le managed their large ships. Splitting the hull into 2 watertight hulls is a simple but effective solution. "Simple" so says one who doesn't have to do it!!
                              Peter
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #45
                                Originally posted by Peter Gillson
                                Chris
                                Peter
                                HI Peter it is fairly simple once you've done a few but things can still go wrong unless you keep a eye on what is bein done as its very easy to make a mistake an mess up all the work that's been done as the hull joint is critical to get it right or things wont meet up I have been busy building the hull joint over last few days an its comin on but thanks for your intrest an im watchin your landin craft thread
                                chris
