an in this pic ive cut out the holes for the plugs to fit into the hull joint top hole will be for the 44 pin electric plug an the square hole for the main power plug
Cheers Steven it seem like ive been workin on this bloomin hull forever but I think the hull is now about 80% finished but im stopping work on the hull till warmer wheather an now doin some eletrics for a change cheers for your intrest in the build
chris
Now in the above pics the plugs were not glued but when I did glue them disaster struck somehow murphys law was present :sad:an the male mains ele plug went off centre by half a mm an the plugs would not meet up so no hull joining so had to sit down an have a think what I was gonna do to put it right bein glueded in they was like rock settin so after a ponder I drilled the male right out an reset it an thank goodness it all worked out ok
nxt the 44 pin electric plugs an these will carry all the low power eletrics eg. for servos an lights an other gadgets that I have not thought of yet until I look through the electronics components book an if my maths are correct there will be 88 wires to solder to the plugs boy I think I need a new soldering iron lol
An here is the rainbow wirein that will be soldered to them I have bought 5 meters of it lets hope it will be enough if not the i'll have to order some more
AN I hope to do all the above over xmas as im gonn do a scrogge an keep on modelling as partys are too much for me so its humbug from me LOL :smiling: :smiling: :smiling:
JEN will proberly join in though
chris the miser lol
