  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #481
    Originally posted by adt70hk
    [COLOR=rgb(163, 143, 132)]Chris
    wouldn't even know where to start with something like this!! Keep up the good work!!!
    ATB[/COLOR]
    HI Andrew well ive done this all before severall times but as the yrs go by its hard to get the good wirein as in my Nimitz I used all steel wire but the wire ive only been able to get is what im usein now an im not really happy with the out come an im ten yrs older now than when I did the wirein in Nimitz so a lot more shakyier getting old im afraid get out the violins lol cheers for your intrest
    chris
    • scottie3158
      • 14221
      • Holbeach
      #482
      Chris,
      Good to see this on the go again. Rather you than me with all the wiring. I'm looking forward to watching the super structure coming together.
      • stillp
        • 8097
        • Pete
        • Rugby
        #483
        Chris, if they're steel, they'll be really difficult to solder. I would say they'd be more likely to give a poor joint than the copper. I've used ribbon cable and those D connectors in various applications, including automotive instrumentation and special test equipment when I was an electronic engineer, and never had a problem with wires breaking. A suggestion if I may - use longer pieces of heatshrink, so you cover all the damaged insulation.
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #484
          Chris,
          Helo Scottie well if all this wirein checks out ok tomorrow then I will be makein a start on the super strucksure as ive bought two 5ft x 3ft sheets of plasticard in 1mm thick as got to keep a watch on top wheight so that will be very intresting to build but as i said firstly the wirein but i will be glad when its done an can tick the wirein off as ok (PHEW IM POOPED ) happy new year to you Scottie
          chris
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #485
            HI again Pete then you may be right about the wire as it did solder easy so I could have gone ahead with the rainbow wire then never mind an yes I like your suggestion about longer shink rap but I would have to split all the wires apart to fit longer shrink rap up to the plugs an doin that now I will proberly cause more breakages so i'll see how the power testin goes tomorrow as I im pooped now but many thanks for your suggestion i'll remember that on all the other wirein im yet to do cheers an happy new year to you an yours
            chris
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #486
              Hello all another small update on the build as I have finished the low voltage wirein harness of 88 wires an they have all been tested with 12v circuit tester an im pleased to say they all passed for good solder joints an D CONNECTOR 'S joint an Pete I think you are right about the wire a pic below of the circuit tester for those that have never used one Click image for larger version
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #487
                this pic im now here doin the circuit tests on the wiresClick image for larger version
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #488
                  AN the rainbow wires harness has passed the tests ok Click image for larger version
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #489
                    Now the greys passed ok an on these wires I have had to put on yellow tags to say which rainbow wire it connects to Click image for larger version
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #490
                      both wirein harnesses now these will be packed away till im ready for them to be fitted into the hulls Click image for larger version
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #491
                        An on this paper the wirein codes so when I come to fit them in the hulls I will just look at this an it will guide me to where which wire is goin where Click image for larger version
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #492
                          NOW HOORAY
                          I can now start on work on the super struckture an I have bought two sheets of 1mm thick by 5ft long by 3ft plasticard but before I start to cut it I will have to swot up on the plans of the S/S so I can understand what im building so till then bye for now Click image for larger version
                          • BattleshipBob
                            • 6804
                            • Bob
                            • Cardiff
                            #493
                            Gordan Bennett Chris thats a whole lot of copper!
                            I would take my hat off to you if i had one lol
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #494
                              CHEERS Bob
                              chris
                                • 18271
                                Good job on those wire looms.
                                Don't know if you already know this but if you have a laser printer you can print the plan out in the size you need as a mirror image, then place them print side down onto the plastic (or plywood) sheet, then iron it with a warm clothes iron.
                                Laser printer toner is basically a plastic and when you warm the paper the print sticks to the plastic sheeting. Saves a heap of time drawing things up....
