Remember it quite well. I used to be an installation electrician. But that was a lifetime ago. And there is a whole lot of difference between Electrician and Electronics Engineer. lol
But OK 40A sounds a lot but I guess over the 4 motors that is only 10A a piece... Maybe an single inline per motor could point to one defect motor and save Chris a few bobs.
But as you wrote we need the power table for the motors or just which motors they are would help. 261 pages is a lot to wade through to find the info...
What does Tiger weigh in at sailing weight Chris? Which motors do you have? Who big are the props? Big props need low speed and high torque.
chrisbComment
So a 9.6v motor on a 12v battery..... Could that be the issue?
Looking at the motors you have given the info on I Would say that they are under rated for the system. As it says on the box you posted nominal 8.4v operating range 6 and 9.6v If you are feeding them 12v they are not going to play nice but you know that.
I would suggest a look at these from Krick. Max POWER 500.
MAX Power 500 electric motor Slowly Rotating, powerful brushed electric motor for various applications. Recommended accessories Electric Motors interference set Article no. | 42128 | Universal suppressor for soldering. Absolutely essential for safe suppression of radio interference by MAX motor seri
Pretty sure you can find them in the UK as well
I did not know that it was two motors per fuse and only two of the motors that are blowing fuses. (just guessing on the info given). Are the motors different form the ones that do not blow the fuse?Comment
chrisbComment
Gives me more questions than answers really Chris. You seem to be running 8.4 volt motors on a 12 volt system? They will therefore be able to draw much more current than they are designed for and quickly take damage. Are you sure that isn’t the root of your problems? What is the spec of the back ones that work successfully?Comment
chrisbComment
chrisbComment
Just did a fag packet calculation in my head…..do you know that each of those Groupners can stall at around a kilowatt each on their rated current…..added together that’s as much a draw as a two bar electric fire…..at best efficiency they each draw like a 100watt bulb.
If you are going to swap them out I would look for 12 V replacements. They should at least match your battery current then, and should simplify problem solving.Comment
What do you recon on the motors I linked to Tim? I read that they can handle a screw of upto 100mm so they should be able to handle the 33mm screws on Tiger in their sleep.Comment
They look more suited to direct drive than the Groupners, revving much slower, so wouldn’t need the belt drive step down. They are half the power output….but if they are more efficient at converting that power into thrust than the Groupners (which are 75%), and are direct drive, which would also increase efficiency, then they could close that gap quite quickly. Trouble is, it’s poor old Chris’ wallet that has to play suck it and see…..Comment
Hi Chris
Tiger looks simply fantastic on the water - a magnificent and graceful looking model. Looks like you had a great day for it too.
It’s a shame about the fuse/motor issue cutting short the maiden voyage but I’m sure you’ll get it sorted.
Hope all is good with you and I’ve fingers crossed you’ll sort the motors in quick time.
All the best mate
PaulComment
