  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #5521
    That's a bit annoying I have had with my car bulbs stop working but when you come to replace them the little sods are working
    HI Peter yes ive also had that problem on my ole relaiant relato but your best bet is spray the light fittin with WD40 that should get the bulbs goin again as thats what i did till i sold the car an went for my test an got a 4 wheel car as my then girlfeind an one boaty mate said it was the only car they ever felt seasick in terrible ride hope yours is better
    chrisb
    • peterairfix
      • Jul 2012
      • 11080
      #5522
      12 inch tyres that are slightly wider not much of an improvement but the rear axle and suspension are new at so it helps
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #5523
        Originally posted by Jim R
        Well let's hope it stays working.
        WELL Jim if its packed up once it will do it again damm
        cheers for your hopes Jim
        Originally posted by Waspie
        Thats electricery for yer!! Stops working - you fly into a panic!! Then when you either try and fix or, like me, get an electrician and find when he calls it all works fine!!!
        Lets hope it keeps on working!
        YES Doug you are right there an yes but i dont think it will so a look inside that gun turret is on when i get them model show over an her next sailin OH DEAR
        ATB
        Not a cold soldered joint is it Chris?
        AN HI Tim it could be but if it was as i pulled the wires tight i think if a cold jiont the wire would have come off as remember i was a welder by trade when i was younger an know all about cold jionts lol but i will find out the prob when i have the time as i think the prob is in the gun turret itself so just as well i made it to come to bits phew ATB an cheers for stoppin all
        Chrisb
        • scottie3158
          • 14220
          • Holbeach
          #5524
          Chris,
          Great work my friend.
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #5525
            WOW Peter so yours is allso a bit bouncy then as i found thats the problem with my 3 wheeler when i took a sharp corner my ole job use to tip to one side an scrape the fiberglass on the rd an talk about put the wind up of passengers but i use to laugh but she was a good ole bus an got me from A to B in the dry better than a motor bike where even with oilesy on id still get wet but you enjoy yours
            ATB chrisb
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #5526
              Chris,
              AN HI Scottie hope you are well my freind an yes it will if i can find out the prob
              cheers for stoppin
              ATB
              Chrisb
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #5527
                HI GUYS well over the week ive been tryin out them motors with the johnsons motors against them two monster motors an well i found with the big motors alot more wind thrust from the props than the johnsons so its all change again for about the 5th or 6th time as ive lost count so its all change an out come them johnsons an in go them other two monster motors an talk about the wind thrust off the bigger props now so now there are all 4 monster motors in her so these should move her an to help the steerin bigger rudder an ive now teid in the bow thruster to help her turn so when i hit the stick to turn the rudder the bow thruster comes in on auto to help steerin an pic of the all 4 big motors now fittered in her
                chrisb Click image for larger version
                • Waspie
                  • Mar 2023
                  • 3488
                  • Doug
                  • Fraggle Rock
                  #5528
                  chrisb [ATTACH=CONFIG]n1207648[/ATTACH]
                  They certainly look the business Chris and the air coming from the props certainly sounds promising. Fingers crossed the rudder keeps its end of the deal.
                  All sounding quite favourable for a successful test next month.
                    • 15743
                    Certainly looks powerful enough. After all your time, head scratching and expense I'm sure this is it! :thumb2:
                    • stillp
                      • 8097
                      • Pete
                      • Rugby
                      #5530
                      Any bigger motors and you'd be able to waterski behind her!
                      • Waspie
                        • Mar 2023
                        • 3488
                        • Doug
                        • Fraggle Rock
                        #5531
                        Hehehehe, they did behind HMS Amazon!!!! Oh - it had gas turbines!! Mind you!!! That's an idea Chris!!! Fit a couple of baby gas turbines!!!!
                        • stillp
                          • 8097
                          • Pete
                          • Rugby
                          #5532
                          Don't encourage him Doug!
                          • JR
                            • May 2015
                            • 18273
                            #5533
                            Chris
                            Looking at that photo of the motor area , wow, there's a lot of work just in that small space. Hopefully you will be able to leave that part alone and sort out the gun problem. You won't relax until it's in the water sailing perfectly will you ?:nerd:
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #5534
                              AN HI Doug yes things now look more promein but one thing is still niggelin me an thats how long that big batt will last powerin them big monster motors OH DEAR cheers
                              HI Jim i only hope so cheers
                              YES THAT would be great Pete but i'll settle for her powerin herself lol
                              COR just think of the Exspence Doug but it would be great an can dream cant i
                              cheers
                              if only Pete
                              Chris
                              AN HI John yes there is a lot of work in that motor eara but my fault really i should have gone big on the motors an props but i was tryin to cut exspences an in the end its cost me 3 times as much Arrrrrccchhhhh but now ive learnt my lesson an yes im leavin it as that motor area is now good to go an gun well i'll sort that but that damm led is still workin amazein anit an no i wont relax till i see her sail around the pond at least twice then i can say success
                              chrisb
                              • Tworrs
                                • Jan 2022
                                • 1982
                                • Garry
                                • New Zealand
                                #5535
                                That looks amazing Chris, fingers crossed for next months trials.
                                ATB
                                Garry
