ATB ALL
chrisbComment
CHEERS Wabble yes im pleased with her an the heat did not help WOW an U/J may have been a faulty one as none of the other 3 were no problem but today gonna call in to my model shop an buy a new U/J an then come home an then rework her prop shaft an refit the new jiont in an no no swimmin as the idoits throw junk in the pond like broken glass an ive seen a shoppin trolley pulled out of the pond so no swimmy lol AN ALL YOU GUYS MAYBE OFF LINE FOR A WHILE AS GOT TO TAKE P/C TO HUGHES SHOP TO HAVE MY NEW NORTON FITTED ON BUT THE SECURITY IS IN THE RED SO THEY MAY SAY WE WILL HAVE TO SEND IT OFF TO BE CLEANED UP AN THEN I WILL LOSE ALL MY PROGRAMS BUT HOPE TO BE BACK SOME TIME SOON
ATB ALL
chrisb
I bear the scars of doing exactly that some 60 years ago. Still makes me squirm just thinking about it.Comment
HI all an today ive just started investigatein that universal jiont prob an firsly i have removed that U/J an had a close look at it an i see that to me the U/J is faulty as one of the brass pins that goes through it has no rivet top on it just flat an can be pulled through the plastic an lookin at the other pin which did not fail this pin has rivet heads on it so the pin wont pull through an it did not so i think that was part of the problem an the other problem i see today is to do with how much currant the motor was takin an the motor shaft is very stiff to turn so more currant drain an its a lot more harder to turn than the other 3 motors so im gonna order another motor to replace this bad one so then will give it another try wish me luck all as i'll need it had more probs on this ship than all the others put togeather Aaarrrccchhhhhhh
ATB all
chrisbComment
ATB all
chrisb
PeteComment
HI Pete TBH i dont really want to do that on the threaded shaft as they are bloomin exspensive about 20 pound ago an knowin my luck id proberly damage the shaft so i'll leave well aloneComment
cheers Sir
chrisbComment
Apologies for missing this Chris, it's brilliant to see her on the water, a testament to the work you've put into her, glad that the only probs you've encountered are reasonably easy to fix , those metal universal joints will really help control the torque from the new motors..
well done buddy, well done indeed..throws a salute your wayComment
cheers
chrisbComment
ATB CHEERS mIckComment
Hi chris
the photos of her are great, she looks superb. i'm sure you must get a lot of appreciative comments when you sail her.
PeterComment
