  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #5641
    Originally posted by Peter Gillson
    Hi chris
    the photos of her are great, she looks superb. i'm sure you must get a lot of appreciative comments when you sail her.
    Peter
    HI Peter yes there are a lot of people come an have a look an talk about the model an they say where can i buy one an i say you cant as they dont sell big models like this in the model shops as they have to be made from a moddler like me an that sort of knocks the wind out of the public's sails but they all seem to like her as the last sortie she was on only lasted 5 mins before she threw a prop shaft due maybe to how powerfull them new big motors are so at the moment im waiting for a new big 775 motor an ive fitted in a new universal jiont so until new motor comes she is u/s in dockyard
    cheers pete for stoppin
    ATB
    chrisb
    • Niho
      • Apr 2022
      • 605
      #5642
      And i thought i was bonkers, go for it Chris!!!!
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #5643
        AN HI Nick yes to do this model lark i think we are all a bit bonkers lol me more so as to the model im tryin to get sailin an yes im goin for it as there is a lot of dosh invested in Tiger so she has got to go
        ATB SIR
        Chrisb
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #5644
          Originally posted by Ian M
          Which RC unit are you using? Is it possible to adjust the throttle to duel rate and have it set to 50% - 60%
          HI Ian a carsons 14 channell T/X yes been lookin through my T/X instruckions booklet an yes i can reduce the power downward to about 70 % full power usein them duel rates but just got to hope it works on seperate channells an not all AS do some funktions may not work so will have a test when my new motor comes an fitted in her
          cheers chrisb
            • 18271
            Normally if you can set duel rate on a unit it is on one ch at a time. It is mostly used in aircraft models but it comes in handy for most others too.
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #5646
              OH i hope so Ian as on my old 40meg the dual rates is on a lever an its100% flick it down an then just 50% but my new t/x not treid it yet
              chrisb
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #5647
                HI GUYS well regards that bad motor well someone on mayhem said the stiff turning motor may need to be run in so i mounted it an screwed it down an ran it for 30 min an now its worst than ever an very stiff cant understand it as ive never had a motor do this before any suggetions ? guys
                chrisb
                  • 18931
                  chrisb
                  Should get looser after running in…..but thirty minutes is quite short.
                  For my railway engines I used to run motors in for about twelve hours in each direction at around 25% speed/power. I would only go to full speed and power once I had done this.
                  Might sound silly, but does it need lubrication? Some motors used to have a felt pad on one bearing that needed a drop or two of machine oil.
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #5649
                    well Tim ive put some 3 in one thin oil on the bearing an spayed in the motor some WD40 AN NO JOY but many thanks for yor info
                    chrisb
                      • 18931
                      chrisb
                      Sounds like a manufacturing issue then Chris. The bearings may not be properly aligned.
                      • Mini Me
                        • Jun 2018
                        • 10711
                        #5651
                        Bin it and cut yer loss....no sense whipping a dead horse. Sounds to me it was a lemon from the git go.
                        • adt70hk
                          • Sep 2019
                          • 10427
                          #5652
                          Chris
                          Very sorry to hear of the motor problems but good to see that she made it onto the water!!
                          ATB
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #5653
                            YES Tim it maybe
                            an yes Rick im goin too as its near jammed
                            Originally posted by adt70hk
                            Chris
                            ATB
                            YES Andrew its one good thing but till i get that other new motor she is u/s
                            thank all
                            chrisb
                            • Tworrs
                              • Jan 2022
                              • 1982
                              • Garry
                              • New Zealand
                              #5654
                              Wow Chris, you are really having a time of it with those motors, I think I must have been lucky with mine.
                              Good luck sir.
                              ATB
                              Garry
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #5655
                                Good luck sir.
                                ATB
                                Garry
                                HI Garry yes ive never had all these probs before an im beginnig to think of tiger is an unlucky ship as get one prob sorted an another pops up an i cannot understand why this has happend as the prop shaft spins freely so yes as Tim has said maybe a bad motor but the new motor wont get to me till november so a while to wait damm an how are you now sir ?
                                chrisb jen
