  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #5746
    Originally posted by Waspie
    Chris, forgive me if I'm all wrong. You're mentioning the fans and obviously cooling. With the Tigers deck in place, is air getting in below deck to allow the fans to take in cool air and at the same time vent the hot air coming from the ESC's? Seems to me, if things are getting hot then maybe it may be a circulation issue.
    As I said, tell me to Foxtrot Oscar, but not knowing or seen in the flesh how it's all constructed, it's just an idea that popped up!!
    HI Doug very good question that you have menchioned an yes cool air gets sucked below the decks by two 2 inch fans that are built in the the back funnel S/S an then there is a big 4 inch fan in side the hull that takes over to blow coolin air down over the motors an the motors also have fans built in an the back cutouots are also airvents as they have no tops on them so coolin it should not be an issue but im not happy with the layout an will change the ESC when i can hopefully next week an fans pics below just behind the rear funnel an im not goin to tell you to Foxtrot Oscar off lol as a very valid qeustion mateyClick image for larger version
ID:	1211782Click image for larger version
    • Waspie
      • Mar 2023
      • 3488
      #5747
      Originally posted by boatman
      HI Doug very good question that you have menchioned an yes cool air gets sucked below the decks by two 2 inch fans that are built in the the back funnel S/S an then there is a big 4 inch fan in side the hull that takes over to blow coolin air down over the motors an the motors also have fans built in an the back cutouots are also airvents as they have no tops on them so coolin it should not be an issue but im not happy with the layout an will change the ESC when i can hopefully next week an fans pics below just behind the rear funnel an im not goin to tell you to Foxtrot Oscar off lol as a very valid qeustion matey[ATTACH=CONFIG]n1211782[/ATTACH][ATTACH=CONFIG]n1211783[/ATTACH]
      Thank you kind sir for the reply. I thought you'd have it covered but worth a mention. :thumb2:
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #5748
        HI Again Doug yes it was worth mentioning as when building a workin model like this coolin has really got to be taken into account so i do a lot of thinkin ahead an then build the model accordinly
        CHEERS Doug for your very valid qeustion nice to see you taken an instrest in the model Sir
        ATB
        chrisb
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #5749
          HI GUYS well ive moved the big fuse box back an moved all them ESC so now there is not no live wires touchin the hot ESC's BTH i dont know if its better or worst as there are so many wires goin through a small space but the all work ok pic of new lay
          out below BTH ITS NOT MUCH DIFFERENT TO THE LAST SET UP OH DEAR
          chrisb
          an here pic of the old wirein layout below for you guys to compare to the new wirein layout Click image for larger version
          • scottie3158
            • 14256
            • Holbeach
            #5750
            Chris,
            Hats off to you mate. Fingers crossed that this is the solution.
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #5751
              an new wierin layout
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #5752
                Chris,
                CHEERS Scottie lets hope so as this is the 6th attempt but now got a few things to sort out as the gun led packed up in model show an big back radar an smoke unit went west also but they had been runnin for 7 hrs so cant blame them so 3 things more to sort out tomorrow Aaaaccccchhhhhh
                chrisb
                • Airborne01
                  • Mar 2021
                  • 4038
                  • Steve
                  • Essex
                  #5753
                  I feel your pain Chris :anguished:
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #5754
                    YES Steve only trouble with a workin model is how long will it keep workin as when in the show things on my ship ran great on the sat but come sunday my freind paul's radar on his sun tug packed up an then about half an hr later mine did very weird that but it was quite hot in the show so maybe due to exspanshion on the radar shaft inside the tube but will find out today as im gonna strip it down to find out the prob an squirt some WD40 in the tube AN SEE then if it will go ok an then sort out other probs an i dont think i will build any more big models as they are gonna kick petroll cars off the rd in a few yrs so wont be able to get to the pond then what a crappy outlook :angry::angry: an they are also talkin about doin away with the phone line an my p/c goes through the phone line so may also be kicked off the web as well OH DEAR :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry:
                    chrisb
                    • Waspie
                      • Mar 2023
                      • 3488
                      #5755
                      Chris wouldn’t a light oil such as 3 in 1 be better to lube shafts, (radar), etc. than WD40? The WD means water displacing so it’s ok for short term but not a long term benefit.
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #5756
                        HI Doug yes you are proberly right thats what i will do use some 3 in one or some thin grease in the tube an ive learnt something from you sir as i never gave it a thought about the WD in WD40 NOW I KNOW LOL THANKS
                        chrisb
                          • 18272
                          I was going to suggest a similar product. It's in a spray lije WD40 but it is for lubrication of cycle chains. Have some but can't get to it right now. Pouring with rain lol.
                          There is always good old grease
                          I saw that the UK was one of the few places not banning petrol cars. But stopping land line telecoms? Go mobil broadband mate. Or fiber cable.
                            • 18958
                            Chris, they aren’t banning petrol and diesel cars, just stopping new ones being sold. Old ones will still be able to be used, and second hand ones will still be for sale. They will still be around for ten or fifteen years. Your copper phone line will be taken out of use, but then your home phone just plugs into the fibre optic that will replace it. We had that happen last year and the only difference is that the phone line is clearer and more reliable…..
                            PS, three in one can attack plastic, so go carefully mate….
                            • Waspie
                              • Mar 2023
                              • 3488
                              #5759
                              Only get the internet through my copper wire. Telephone has been of the VOIP variety for yonks. (Last two houses so that's gotta be some 12 years now). No difference noticed at all, even SWMBO thinks it's a standard BT phone and I really can't be bothered to start complicating her life telling her otherwise!!
                              WD40 has its down side too Tim, it dislikes rubber, will perish it earlier than it normally breaks down. End of the day, use the correct lubricant for the job in hand. EG, I use silicon grease for rubber, all my car seals are wiped with a cloth and silicone grease. Hinges - normal grease. Hot metals a lead based or copper grease depending on location!! Horses for courses I guess.
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #5760
                                HI Ian yes i'll proberly use a thin grease then
                                AN HI Tim well it was sayin on the web news this morn that all petrol an deasil cars will be banned off the rd by 2030 an hybrids are goin to be off the rds by 2035 so got me worried as mine is a petroll car but if as you say then i need not worry then an can maybe build another model ship then oh many thanks for that
                                chrisb
