  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #991
    an here the servo is mounted on the H-deck underside fitted with its proper length arm to pull the door up an down an its all in place screwed down but can be easysily removerd if I need to Click image for larger version
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #992
      next pic servo in motion by R/C opening the H-door an as can be seen the pushrod bends quite good but still strong enough to push back up to close said door Click image for larger version
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #993
        door now fully open Click image for larger version
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #994
          AN NOW half way closeing Click image for larger version
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #995
            an shutClick image for larger version
            • tr1ckey66
              • Mar 2009
              • 3592
              #996
              Quality stuff.
              I'm half expecting miniature working sailors next on this build!!!
              P
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #997
                WELL now over to work on the other H-door as these two doors will be wired up to a Y lead an both on the same R/C channel so when I hit the switch both the doors will slowy open by me fittin in a servo morph.
                this is a devise that allows the servos to be set to different speeds an it will if set to slow the servos will take up to 30 seconds to open or quicker whatever I desire an ive never used one before so will see how it goes .
                but now ive come across the unexspected !!!!!!
                now as the servo has to face outward I have come across that the servo when activaited will only push upwards an not downwards to pull open the H-door so I have a major problem that reqiures a bit of thought how to get around this
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #998
                  Originally posted by tr1ckey66
                  Quality stuff.
                  P
                  HI PAUL great to hear from you an yes if only
                  chris
                  • scottie3158
                    • 14221
                    • Holbeach
                    #999
                    Chris,
                    I really love the way you engineer your way around the issues.
                    • Fernando N
                      • 2448
                      #1000
                      Love the working door, fantastic how you’ve engineered the workings for this:smiling:
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #1001
                        Chris,
                        HI Scottie thanks for your comments an stick around because ive though of a way out of my servo problem but just got to hope this idea will work some more engineering pic comin up in a minute
                        chris
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #1002
                          HI Fernando glad you like the workins an still a lot more to come on this build if I ever finish it thanks for droppin in :thumb2:
                          chris
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #1003
                            WELL I worked how im gonna get over the servo problem but its a little tricky
                            here we go now to put it to rights ( I HOPE ) FIRSTLY take the servo to bits an as I go take a pic at each stage so I can see how it all (HOPEFULLY) goes back togeather the first stage Click image for larger version
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #1004
                              second remove the gears an number them Click image for larger version
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #1005
                                an third all gears removed now as this is an old sevo but works ok I was hopein the bottom section would be able to be removed so I couldClick image for larger version
ID:	1124785 see the motor terminals but no joy this is goin to be aweward to say the least
