  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #1021
    HI ALL well the operation started ok Click image for larger version
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #1022
      how it was before op Click image for larger version
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #1023
        an after the op wires swopped around Click image for larger version
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #1024
          the patient back togeather an FAILURE there must be something in the pcb board that makes it only work one way as it wont accept the signal power so i stripped it all down an done some tests an no JOY.
          so again i thought well i dont want to lose a good servo so i stripped it all out again an the soldered the wires on the motor back how they were originaly then put it all back together an hey presto it all work again ok SO THAT A LESSON LEARNED .
          but i enjoyed tryin as i cannot see why it wont work but as i said it must be something in the PCB BOARD OH WELL WE LIVE AN LEARN NORMALY THE HARD WAY BUT THAT LIFE BUT IM NOT USED TO FAILURE SO I WILL THINK UP ANOTHER WAY
          now the only way i can think to get the hanger door to work on that side with any servo is to make up a gearbox to fit to the servo fitted with its own gear an then mesh them togeather an by rights when the servo turns the wrong way the gear fitted to it WITH A PULLING ARM will pull in the oppiste way so it will work the H-door ok but it will be a bit more complex but first i'll have to do some scetches to see what im happy with DUH :rolling: :loudly-crying::smiling:
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #1025
            AN my servo morph turned up by postie this morn an my collars for the radar shaft so im still a happy bunny a bit disappointed that the servo dint work but now I know I will not attempt that again so onwards an upwards as they say an keep tryin till I get it right Click image for larger version
            • wotan
              • May 2018
              • 1150
              #1026
              Very interesting to follow your exploits. BTW suppose you just mount the servo upside down?
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #1027
                HELLO John I treid all that before my recent exploits. an no go but many thanks for your thoughts on this suject but i'll get there its just mind over matter (i'll proberly gone bonkers by then lol ) an nice to see you takin an intrest in the build but it will get done by hook or crook as the sayin goes
                ATB STAY SAFE chris
                • ojays
                  • Oct 2011
                  • 1713
                  #1028
                  Could you not put a crank/pivot along on the Hanger wall, connecting the snake to the door connection lever to reverse the push/pull motion.
                  Alternatively if you want to keep the HB clear, put a 90 degree link where the servo is.
                  Just a suggestion.
Name:	Hanger  Door 2.JPG
Name:	Hanger Door..JPG
ID:	1125306 half way
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #1029
                    Just a suggestion.
                    [ATTACH=CONFIG]n1125307[/ATTACH]
                    [ATTACH=CONFIG]n1125306[/ATTACH] half way
                    HI Gregg many thanks for your suggestins an givin it some thought very nice of you. But Ive already worked out how its gonna work an it will as ive already fitted in the fittins for it to work but I cant carry on with it yet as its a case with the radar motor fittin havin a knock on effect I cant do the H-DOOR until ive fitted in the radar motor an sharft which has got to be removeable.
                    Then ive got to fit in a false back hanger wall so that all the workins will not be seen then when done that then I can get back to the H- DOOR but CHEERS all the same thank you for takein an intrest in the build as when you guys come UP with something like you have it maybe just the idea that im lookin for
                    AGAIN CHEERS Chris
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #1030
                      HI ALL UPDATE time
                      well i'll start off with a pic of that radar shaft goin through the front wall as its got to be there as the main mast shaft is centrall to the front H-wall Click image for larger version
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #1031
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #1032
                          now here ive cut down the R- SHAFT an fitted it with a brass box section as the main mast shaft will have a smaller box section fitted to it so that it can just drop in it to turn the radars but will be detachable in I need it to Click image for larger version
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #1033
                            an its fitted in place with the smaller box section in so as the shaft turn so does the top section but can be lifted out Click image for larger version
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #1034
                              an here it is lifted out just leavin the mounting box section Click image for larger version
                              • BattleshipBob
                                • 6804
                                • Bob
                                • Cardiff
                                #1035
                                Gets better Chris, really admire this build:thumb2:
