  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #1111
    an this is only a balsa sided gearbox just to see if it is goin the right speed Click image for larger version
ID:	1127283an it is so I built a better one with hard wood Click image for larger version
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #1112
      an in the end I used two of the same gears on the mast top Click image for larger version
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #1113
        a rough bit of balsa to test if the shaft speed is right an it was ok so I could press on Click image for larger version
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #1114
          an as the main search radar is set well forward so it misses the rear mast I had to use these gears Click image for larger version
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #1115
            an on the plans its set up an inch higher an I also had to use a bit of modelers
            licence as had to build a gearbox to cover up the gearing Click image for larger version
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #1116
              an on the very top it still needed two gear in a gearbox to make the radar go round the right way Click image for larger version
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #1117
                an here it is an it goes mainly ok but on one gear has a high point an jumps slightly but im hopin it will bed in when its been goin round a few thound times Click image for larger version
                • tr1ckey66
                  • Mar 2009
                  • 3592
                  #1118
                  That looks incredibly complex Chris. Nice work on the Radar array workings.
                  Paul
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #1119
                    well im ive done most of the work on that top radar so its down now to the halfway mark to fit on the navigation radar which is a bit smaller but first ive got to find an fit the right gears from those below Click image for larger version
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #1120
                      Paul
                      HI Paul yes it is a bit complex but im enjoyin doin this but got to be carefull how I handle the whole affair as its a bit fragile at the moment an cheers for lookin in
                      chris
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #1121
                        the mountin for said radar has to to go off the mast at a 45 degree angle so ive had to cut through one of the main spars for the r- shaft to fit to the yellow crown gear that goin to power it an it will all just unscew an lift off Click image for larger version
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #1122
                          top view lookin down on it an you may notice ive take both bridges off to stop them getting damadged while im building this Click image for larger version
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #1123
                            front view as there as got to be an awefull lot of masts an sensorer an white steamin lights an red anti collishion lights still to be fitted but cant build them yet as im waitin for the brass rod comin from ebayClick image for larger version
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #1124
                              nav R- mountin Click image for larger version
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #1125
                                an here ive fineally sorted out what gears I will need an just for now till tomorrow laid them on an again the gear units will be built in but all will be removeable in case any gear start slippinClick image for larger version
