  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #106
    HI all a few more pics about how far the build is along getting nr the stage to start to cover hull Click image for larger version
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #107
      ALL quadrons fitted to give the hull strength front veiwClick image for larger version
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #108
        Rear view Click image for larger version
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #109
          AN now startin to cover the hull with 1mm thick ply an do what I call a ply wrap round as plank on frame needs so much filler an it adds to much wheight this way its lighter Click image for larger version
ID:	1096308to carry to the pond
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #110
            HI ALL well hav'nt been on site for a few days as been busy buildin
            an started proper to cover the hull in the next few pics
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #111
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #112
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #113
                  Nearly halfwayClick image for larger version
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #114
                    Now covrerin hull joint got to be carful here as I mustn't get glue in between the H/J or I won't be able to part them Click image for larger version
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #115
                      Hi all well bein stickin into the hull build an as of today I have finally covered the hull with some help from my SWMBO she has been sortin out the bent pins an handin me the straight ones an been an immence help to me so now I have to leave it for 24 hrs for the glue to go off an then tomorrow it will be
                      time to undo the screws that hold the hull in place then gently lift the hull off the Sellotape on the build board an see how it looks an remove the plasti card spacer from the hull joint an the hull bolts an cut her in half. Boy will I be sweatin doin this anyway some pics of what she looks like now Click image for larger version
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #116
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #117
                          NEARLY THERE A SHOT FROM THE STERNClick image for larger version
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #118
                            the hull lookin a little rough but when ive filled all the tiny gaps an sandin sealed her then sanded the hull down it will look a lot betterClick image for larger version
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #119
                              last seckion of ply to go on the bow Click image for larger version
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #120
                                an fittedClick image for larger version
