  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #1186
    HI ALL another small update on her an i found the main gear shaft was slippClick image for larger version
ID:	1128650in on the R-SHAFT as the collet that was on wont tighen up enough so i had to strip all the motor out of the front of the hangar bay an refit a nice big brass one on an now its got a good allen screw in it so it really tighten up now on the shaft so no more slippin
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #1187
      An now back to that back height finder radar an its all built Click image for larger version
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #1188
        AN COVERED IN an it all works fine Click image for larger version
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #1189
          NOW ive got to buy that big search radar on the back main mast a shot here of it on the plans Click image for larger version
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #1190
            AN I was very lucky as jen phoned up fleetscale to ask i could buy one an he checked an he said you are in luck as you have got the last one an its in P/E
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #1191
              But ive still got to build it an postie also bought me 400 brass stanchions for the ships railins Click image for larger version
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #1192
                AN ALSO a whooper battle alarm sound unit with its 3inch speaker an the speaker will be fitted in a sound box beneath the deck under the grillClick image for larger version
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #1193
                  A couple of overall shots of the main mast Click image for larger version
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #1194
                    an front view an ive also had the brass rod delivered now so i can get on with the mast gantry an fittin in the red anti collishion lights an white running lights Click image for larger version
                    • tr1ckey66
                      • Mar 2009
                      • 3592
                      #1195
                      Awesome work Chris. Outstanding engineering and electronics this is such a wonderful project to follow.
                      Keep up the great work.
                      All the best
                      Paul
                        • 22788
                        #1196
                        Some fantastic work going into this Chris.
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #1197
                          All the best
                          Paul
                          HI Paul many thanks for you kind comments an yes im really enjoyin this build an it will get a lot more intresting when i can start properly on the eletronics an lights an such but i just got to finish building the S/S THANKS FOR LOOKIN IN
                          AN HOPE YOU ARE WELL
                          ATB chris
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #1198
                            AN Glad you like this build Ian yes im havin fun on this build
                            chris
                            • ozdell
                              • Apr 2020
                              • 365
                              #1199
                              chris
                              Hi Chris, wow you have come a long way with the main mask and making a start on that brass radar, be a night,are indeed, have a good soldering iron where you can control the heat,, have a good soldering, hiw do those little parts fit, do they clip in place.
                              I have made a start on the other side of the last hull section, got one bulkhead in place, can't do any more work getting late here 10.51 pm, got the ply to build the second corner module, can't do any work outside rain coming in till Tuesday.
                              Take care Tony from wet down under
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #1200
                                HI TONY nice to hear from you an what little parts are you on about that clip in place ?
                                CHRIS
