Chris,
The great work continues. I don't envy you with the radar assembly but your just the man to take it on.Comment
ATB chrisComment
AN AFTER fittin in the runnin light nxt up was the fittin of the 2mm red anti collishion leds an this was a bit tricky as i wanted to run the wirein along inside the 2mm brass box section an it worked out fine thank goodness a few shots of it happening.Firstly in the brass cross member i had to use my dremel to grind off half an inch of the bottom so that as i feed the wirein through it will come out inside the mastComment
Hi Chris
Fabulous work on the LEDs/lighting and the radar tower in general. It all seems to be coming together now. This model will be epic when finished and a great partner to your HMS Norfolk. With regards to the etch, I’d probably solder it, but i see you’re dilemma in painting it with rattle cans.
Looking great! Keep up the fabulous work
PaulComment
Hi Chris
Paul:rolling::smiling: but if i solder it i'll burn off the paint inside them box sections
so superglue is to me the answer as it wont get hot an damage the paint an yes she with Norfolk will look great but i wont be able to get them both togeather up the pond as only room for one in the car an thanks fo your nice comments an lookin in on the build an whats happening on the panzer ?
ATB
chrisComment
ATB chrisComment
