BOATMAN's USS NIMITZ CVN 68 BUILD IN 1/144 SCALE
  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    HI all well I have finally managed to convert all the build pics from bitmap to jpeg some pics wont be as good as as others as I had an old camera at the start of the build but they will get better as I bought a new one a little later .
    Now this is a 7yr scratch build using a limted plan an to try an scale it right a ( 1/7OO I THINK ) plastic model of this super carrier an on the r/c it had 19 functions that work different things on the ship an the first pic is the keel without which there wont be a ship here we goClick image for larger version
  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    Nxt pic the hull frames cut from 1/4" marine ply with HULL JOINT FITTED Click image for larger version
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      An its built upside down as the keel an some hull frame are screwed down to build board to stop the mode twisting or becomein a banna hull only good for goin round corner's :smiling3: an here in the nxt pic I had fitted the 1/4" quadtron's to give the hull strength
      an I don't do a bread an butter covering as I think it takes up to much filler an creates more wheight so I opted to do what I call a 1/32" ply wrap roundClick image for larger version
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
Name:	carrier build4.jpg
        • Steven000
          • Aug 2018
          • 2830
          • Steven
          • Belgium
          Beautiful project :thumb2:
          It sure takes commitment to work on it for 7 years.
          Cheers, Steven
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            Now the covering or skinning as some calls it is under way I used PVA wheather proof glue an small tack pins to hold the ply in place while its glueing Click image for larger version
Name:	carrier build5.jpg
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              Here at this stage of covering it got very awkward as the ply skin has got to be bent three different ways to give the curves of a carrier Click image for larger version
Name:	carrier build6.jpg
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                Cheers, Steven
                Thanks Steven I must admit that I dint realise what I had let myself in for as my friends were sayin go on an build it as no one eles has done it around my area so I thought ah a challenge here an it most certainly was (PHEW)
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  Still covering nr a week later workin on it every day as I thought ive got to get stuck in or it will never happenClick image for larger version
Name:	carrier build7.jpg
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    nearly thereClick image for larger version
Name:	carrier build8.jpg
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      HULL now cut in half an I sweated bucket's doin this as it was make or brake time but it all turned out ok (PHEWEE) then I did a little dance around it to celibrate :smiling::smiling::smiling:LOLClick image for larger version
Name:	carrier build9.jpg
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        Here building the bow Click image for larger version
Name:	carrier build10.jpg
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          An now here she's lookin like a super carrierClick image for larger version
Name:	carrier build11.jpg
                          • Mickc1440
                            • 4786
                            That looks very impressive.
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              Thanks mick but it will get better as it goes
                              chris
