Minicraft 1\350 RMS Titanic
  • peterairfix
    • Jul 2012
    • 11083
    This is one that I have never done from the start as all the others I have done have been all been started in some way.
    A nice kit and apparently the best one out there and it does have the five porthole arrangement on the port side on the bow.
    Here's what is in the box.
    I could show all the spures but I would be there for a long time as there is so much.Click image for larger version
ID:	1093021Click image for larger version
  • Allen Dewire
    • 4741
    • Allen
    • Bamberg
    Wow Peter,
    That does look like a whole lot of parts. I see the hull is molded in black plastic too. What is the gold pieces sprue for?
    Looks like you have your work cut out for you. I'll watch if you don't mind...
    Allen
    • peterairfix
      • Jul 2012
      • 11083
      They are parts for the stand and the stand nameplate.
        • 22788
        Wow Peter,
        Allen
        The gold parts look like a stand to me Allen
        Peter just beat me with the answer.
        • Allen Dewire
          • 4741
          • Allen
          • Bamberg
          Thanks Guys,
          I had thought that too, but I wasn't sure. I'm not too hip on big boat kits I'm afraid. Gonna be a big one for sure!
          • peterairfix
            • Jul 2012
            • 11083
            Started putting some colour on the hull and have attached the two wing props and the two bilge keels and have started on the yellow stripe witch are decals.Click image for larger version
ID:	1093118Click image for larger version
ID:	1093119Click image for larger version
ID:	1093120Click image for larger version
ID:	1093121Click image for larger version
ID:	1093122Click image for larger version
              Peter,
              Very sorry to be negative about the model moulding - but that plating doesn't look good - more like wooden planking than rivetted steel. At 1/350, it should be pretty flush. Short of sanding it all off & rescribing, I don't there is an easy way to remedy this. :worried:
              • peterairfix
                • Jul 2012
                • 11083
                Peter,
                It's probably down to moulds they have been around for a bit I think they started out as company called entex industries then Anmark then they went to academy and finally minicraft.
                • eddiesolo
                  • Jul 2013
                  • 11193
                  It is a great size and does have some superb detail, as pointed out the hull plating is a let down on a model this size-as pointed by Peter, the moulds are not great.
                  Now to the model, nice paintwork mate, nice lines on the black and the antifoul. You and Titanic/Olympic models do seem to be drawn together. I am sure this will another of your top builds on this genre.
                  • peterairfix
                    • Jul 2012
                    • 11083
                    I have just been on scalemates and have traced this kit back to 1976 when it was Entex industries and I have a reboxing of this original kit even though it's dated 1997 hence the poor quality moulding.
                    • eddiesolo
                      • Jul 2013
                      • 11193
                      Yeah, I was wondering that it was rebox. Still, I know you will make a cracking finished model.
                      • peterairfix
                        • Jul 2012
                        • 11083
                        Started on the cabin walls and vents and a couple of benches plus a piece of decking added.
                        All the vents will have to be drilled out as they come flat.Click image for larger version
ID:	1093212Click image for larger version
ID:	1093213Click image for larger version
ID:	1093214Click image for larger version
                        • peterairfix
                          • Jul 2012
                          • 11083
                          I have started on the upper decks I have the promonade deck and boat together and the bridge front has been painted and attached.Click image for larger version
ID:	1093411Click image for larger version
ID:	1093412Click image for larger version
                          • peterairfix
                            • Jul 2012
                            • 11083
                            Moving on to the next part this time it's the turn of the officers quarters and funnels one and two to be finished and rigged and all the vents and I have finished the first class dome and coverClick image for larger version
ID:	1093649Click image for larger version
                            • Allen Dewire
                              • 4741
                              • Allen
                              • Bamberg
                              Wow Peter, you are really moving along on this puppy. Looks good too! I was wondering what all the loose cords were for and then your last two pictures answered my question. I never knew the stacks had cable supports...
