Artesania Latina Cutty Sark
    Hi all i bought this off my brother (he decided it was too frustrating for him) there are a few problems to sort out on it (I need to strip the decking off and square the frame up , it's a bit warped) he took the planking off which has saved me a job (he bought some really thin wood for the planking as he struggled with the supplied wood but it's so thin I can see it disappearing when sanded do I'm going to use the supplied wood) here are some pics, I've managed to get the deck off fairly easily getting the wood off the deck and squaring the frame may be quite a bit harder.
    This will be a very slow build.
    [ATTACH]358699[/ATTACH]
    [ATTACH]358700[/ATTACH]
    [ATTACH]358701[/ATTACH]
    [ATTACH]358702[/ATTACH]
    [ATTACH]358703[/ATTACH]
    [ATTACH]358704[/ATTACH]
    [ATTACH]358705[/ATTACH]
    [ATTACH]358706[/ATTACH]
    I think the pins hes used in the transom are way out of scale.
  • boatman
    • Nov 2018
    • 14477
    • christopher
    • NORFOLK UK
    HI Ken i'll be following your build cutty sark looks a treat under full sail if you can build her an I hope you can good to see another floaty build on here how big is she length an beam ? an the scale ? an yes these ships take a fair while to build as they are a work of art good luck on her
    chris
      Hi chris barring bowsprit (not added yet) she's a yard long, it's a very impressive kit.
      • boatman
        • Nov 2018
        • 14477
        • christopher
        • NORFOLK UK
        OH I say Ken she's a fair size then that should keep you busy whats she just gonna be a static model then ?
          Hi all well I've removed the deck planking squared up the frame and are attached the front decking. I thought I would get away with doing nothing to the rear deck but on closer inspection I think he put the last 2 bulkhead the wrong way round since the second to last is narrower than the last (the phrase one step forward 2 back comes to mind) anyway I managed to get the rear deck off now I'm not sure what to do the frames seem to be impossible to unglue, any suggestions (I've tried steaming over a kettle but they won't budge) would it hurt the plywood if I soaked the stern in a bucket over night.
          [ATTACH]359336[/ATTACH]
          [ATTACH]359337[/ATTACH]
          [ATTACH]359338[/ATTACH]
          [ATTACH]359339[/ATTACH]
          [ATTACH]359340[/ATTACH]
          [ATTACH]359341[/ATTACH]
            • 15698
            Hi Ken
            Quite a task you have set yourself. I imagine these wooden ships are long term projects. It certainly looks as if those two bulkheads are the wrong way round. Rather than try to remove them and risk damage could you saw/sand a little off the last one and add a little to the narrow one? Just a thought.
            • boatman
              • Nov 2018
              • 14477
              • christopher
              • NORFOLK UK
              Originally posted by Jim R
              Hi Ken
              HI Ken Jim is right as ive had to do this on most of my ship 's scratch built hulls as the plans are not a 100% right an some time the hull frames are bigger or smaller than they should be It happend on my tiger build as my plans were 3mm out by the time the hull frame is drawn an cut out it goes either way.So out comes the dremel to put the hull frame to rights also you wont have to risk damageing the keel an to build the hull frame up to its correct size I use hard balsa which is easy to work on
              chris
                Thanks guys, I think that's the way I'm going on this. I will measure the widest one and the smallest then add to the smallest and remove from the widest.
                • boatman
                  • Nov 2018
                  • 14477
                  • christopher
                  • NORFOLK UK
                  Spot on Ken :thumb2: you will find it saves a heck of a lot of work
                  chris
                  • tigersteve
                    • Jan 2018
                    • 678
                    Good luck with this build , I'll be watching with interest. I started one of these last year and put it away as I have been travelling a lot and worry it's a bit too much above my skill level! Click image for larger version
                    • peterairfix
                      • Jul 2012
                      • 11075
                      I am looking in as I still have the bounty to finish.
                      • Neil Merryweather
                        • Dec 2018
                        • 5189
                        • London
                        I am watching because I have their HMS Surprise as my retirement project.- WAY out of my league and experience(never built a ship....) but something I've always wanted to do.
                        good luck
                        N
                        • boatman
                          • Nov 2018
                          • 14477
                          • christopher
                          • NORFOLK UK
                          AN im lookin in as im building my hms tiger
                          chris
                            Thanks guys, more the merrier. I've built a few scratch built ships but only one wooden ship kit Amarti I think. The brumer yacht.
                            Nothing like this if it had been an unstarted kit I think it would be at the limit of my skill set, this will be a huge challenge.
                            • boatman
                              • Nov 2018
                              • 14477
                              • christopher
                              • NORFOLK UK
                              Well Ken for me that's the whole idea of a challenge like my tiger ive never built a battle crusier before an im glad to say its comin on great so there's the challenge of the build an the immence enjoyment when workin out how things are goin to be built an you will have the same enjoyment (hopefully )
                              chris
