Revell 1/96 Cutty Sark
Pretty sure BC will BB (Bobby Conkers will Be Back) hopefully sooner than later.
That's good about Ken, us plastic guys got to keep you spectacular out of control scratch from wood, with no concept of limitations guys in line. I have been plugging along on mine, sorting out and painting on the hull sections and the decking so should have some pictures of progress in a couple or so, had a broken off piece on a railing section missing so I am joining the gang of missing parts that go boing in the night, how can a piece escape from a completely sealed plastic bag. Will be lining the walls of my workroom with aluminum foil, this alien abduction crap has got to stop.
BTW the behemoth is looking really good, coming along great.Comment
ATB stay safe chrisComment
Actually my favorite, but played around before I resized it for here and wanted to get a feel for the gang because of the wording underneath it. This one will stay.Comment
Greetings fellow mogglers!
I return. Moggle building is very much an autumn/winter hobby for me, I just like being outside too much when the sky is a lighter shade of grey.
But I do not desert you. Rigging - to do. Sails - to decide upon. I also have to finish off my speed build of a submarine which also got parked in March.
I am back, let us see how the endeavour (not The Endeavour) will end.Comment
chrisComment
Hi all.
Looks like I'll be back on this soon.
Some advice please. These bits (climby rope things for the masts) just have a matt black for the painting instructions.
I don't have the patience to make my own from fibre, so how would you paint these to make them look a little less 'painted black plasticky'? Any ideas?
[ATTACH]412280[/ATTACH]Attached FilesComment
They were tarred rope I think, so Matt black dry brushed a lighter grey to bring out the texture would work as well.....Comment
As Tim says the shrouds (long vertical bits) were tarred black the ratlines (crosswise bits) would have been more ropey from wear. The little bits at the bottom, lanyards, pieces 180 and 168 and the bits they cover, would be rope coloured since they are the working bits used to tighten the shrouds.
By the way this is looking very nice and glad to see you have got back to it.
JohnComment
Thank you all.
I think I will try some dry brushing as Tim suggests, just got to get some weathering in there. Wotan, you make a good point, there will be foot scuffing on the horizontals. I might try some unmixed gunmetal for the verticals actually, that will give a variety of shading and highlights, as long as it doesn't look too metallic afterwards. Them maybe some wood base dry brushed on the ratlines.
Experiment time!Comment
Hi mate
I would be tempted to go with a base coat of dark grey, highlights dry brushed with lighter grey, then pin washed in black. Make sure all the seam lines are gone though, this will make them stand out like a sore thumb!Comment
I'll see how long one takes, and thank you!Comment
Try one of the game washes Bobby. I use Vallejo games washes a lot. They are formulated for this type of work and flow very well. You would be able to basically splash it all over like Henry.....and it will flow into creases etc. Any excess where you don’t want it can be removed with a damp brush before it dries....Comment
