Trumpeter USS North Carolina BB-55 - 1/700
chrisComment
It's a different mind set to aircraft thats for sure. But it is a lovely ship and patience is the watch word. Given how sub atomic in size some of the parts are any tips on when to apply any paint Chris ? Do I build then spray some primer or build and paint the individual parts ? When do I do the deck, which I'll do in my own mix to get the deck blue, which I think is a sort of grey/blue. Only 9 colours in all and a couple of thse gold and yellow are minimal so 7 really 4 of those are a grey and 3 blues. I might be a bit creative but keep close to the minimalist themes these ships hadComment
That makes sense. With so many tiny parts such as small cranes and guns I wasn't sure if to paint them, light grey, on the sprue and then fit. The units I can see where build and paint seperately. I have a 0 and 00 newton & winsor brush set so can do the fine work. Its an odd camo design with huge stripes of dark navy blue and light grey across most things. Looks very nice but will be a had painting job for sure.Comment
all best to you gary an happy modelin i'll be following your build as I love them battle ships
chrisComment
Thanks again Chris. It really is a different planning process than aircraft in quite a few areas. You can do similar with planes but most of teh time you build linear with a few pieces seperate until late on. But I can see with these boats that building in in specific units and treating almost as a seperate mini model is better. I've not stuck too many tiny cranes and hoists on yet so will sit down and have a think about whats next.
After 30 years as a project manager it should be simple right ? :tears-of-joy::tears-of-joy::thinking:Comment
Hi Gary.
I've done quite a few of these great 1/700 ships.
I paint the hull, decks then any 'Dazzle camouflage' and only then do I add the bits and pieces. It is far easier to do the dazzle and or decks, with all the bits out of the way.
Personally, I wouldn't bother painting all the smaller bits to match the camo. colour. I leave them whatever colour they should be without the camo.
Having written the above, I'm sure other modellers have a different approach to the painting process, it's just the above way works for me.....
The painting is relatively straight forward. It's all the rigging that destroys the will to live, but it has to be done.
Good luck with the build when she's on the stocks!
RonComment
I'll post some photos tomorrow when its daylight. But these ships are addictive and I've completed the upper structures and stuck them to the deck but boy was that intricate. But oh so much fun and time just flies by. I'm glad I've got a wooden floor so finding the tiny parts that ping off the tweezers is fairly easy. I'm also going to make a practice seascape out of 9mm MDF and filler as I've got that to hand. If I get time I'll PVA and paint at the same time but baby steps....Comment
