Hi Tony 26 F. here and sunny after two days of nonstop snow....12" at least. If I were to do the railings, I would do them in sections but first I would make a template for each section using careful measurements of course. Each template would have marks on it to precisely locate each vertical and same for horizontals as well. The end verticals of each section must be independently located on the walk way at the proper angle first. Also, if you make the sections just a tad long then they can be trimmed to precisely fit between the end verticals in each section. If the railing is not going to be subjected to any handling or stress I would build it out of Evergreen plastic rod as it comes in lengths of 14 " Hope this is helpful....just my thoughts. Rick H.
Ozdell's 1/87 scale Ro, Ro ship Coroan Sea build
Hi Tony 26 F. here and sunny after two days of nonstop snow....12" at least. If I were to do the railings, I would do them in sections but first I would make a template for each section using careful measurements of course. Each template would have marks on it to precisely locate each vertical and same for horizontals as well. The end verticals of each section must be independently located on the walk way at the proper angle first. Also, if you make the sections just a tad long then they can be trimmed to precisely fit between the end verticals in each section. If the railing is not going to be subjected to any handling or stress I would build it out of Evergreen plastic rod as it comes in lengths of 14 " Hope this is helpful....just my thoughts. Rick H.Comment
You already have the angle.........it is the same as the face of your bridge.....you have some great photos to work from. If you look at the angle of the railing and the angle of the windows on the starboard end, they are parallel. Also, looking at the first photo in this post, I can project that the height of the railing coincides with the bottom of the windows or maybe just a little higher....not enough to impair the view as that would not work well for the crew that are navigating this vessel. Reminder: The railing is only angled at the Pilot house and at the port and starboard ends of the walk way, the rest of the railing is vertical to my eyes. Please correct me if I am in error. Rick H.
ps. actually, it is 4:45 pmComment
The last pic of Corona Sea, good pic of the rear window panel and the accommodation deck bridge deck, is a walkway and hand rails, going to fix that window panel , Take care Tony from down under.Comment
HI Tony yea Ricks advise is good but looking at an studying your bridge layout picture by rights the side's front walkways are on the top of the main S/S all you have to do is place your bridge in the corret postion on the main S/S an by rights the main S/S will be the walkway on the sides an the add a walkway width around the front small bridge useing gussets to support it easy peasy as lookin at the pic thats how it looks to me any way can you please Tony show a pic from top veiw looking down on the top of the bridge so i can see if thats how it should be an how you have built it ? PS Tony look at the next page for a diogram
chrisComment
Tony below in the rough quick drawing is how i see your bridge layout all it seems to me i that your top bridge floor is cut too short so you will have too extend the bridge floor right up to the main S/S front an there you will have your walkway an then as i say in the diogram extend the small bridge over hang an fit supports gussets underneath any way the diogram its not a 100% right as i havnt got a top veiw of your bridge hope this helps you
chrisComment
YEA Tony lookin again at your main bridge pic of your build you have gone a bit wrong this is not criisuim of your build its just an observation but you have cut the bridge floor right where the the front bridge windows will be where as really you should have taken the foor right to the front of the main S/S an that would be your walkway an then just built the bridge window up on the floor sorry i dont mean to be rude here
chrisComment
chris [ATTACH]414512[/ATTACH]
I am waiting for the captain to re-join Jutlandia Sea first week of March, he said he will take those needed pics, just looking at the plan the yellow line past the window is the walkway Tony from down underComment
chris
Last two pics of the bridge in place , heaps of work still ahead , getting there , a couple of hot days coming up and rain after that, wont get much of a chance to get back to the layout, went down to the shed before tea and marked where the fist station module be going. Tony from down under on a highComment
TonyComment
WEL Tony from what i can see is if you extend the bridge floor to the front of the main S/S you will be right as from what i can see looking at the ship pic the walkway is not raised off the deck all i can see is the walkway bein difined by the railing an tryin to fit the window glass in flush well you will need to do it on each window an thats where ive always come unstuck as there may be glue smearded onto the glass so i just fit one long lenght in side the bridge an glue lightly top an bottom an yes my glass is a light green acetate as ships have this colour fitted to cut down the suns glare off the sea but good luck on fitting the windows flush as remember Tony it only takes one tiny little glue smear to ruin the whole bridge an on my warships the glass is set back in the frames as its toughened glass to withstand nrby exsploshions
chris
ps tony another bit im a bit confused on is what you said below
(tony quote)
the bridge be glued too so I can have access to the LED lighting,
SO tony if you glue the bridge glued do you mean down to the deck if so how will you have access to the LEDS ? as im missing something in your thinking here again Tony sorry dont mean to be rude
chrisComment
chris
(tony quote)
chrisComment
Here is the question confusing pic again, the roof panel that fits flush underneath bridge be glued to that panel, will keep the bridge in place as well will lift out for access.
I have some fixing up to do on below the rope room near where the anchor fits, didn't match well, luckily with cardboard can be an easy fix do that job later.
Tony from hot down underComment
Finely closed in to roof of the front accommodation deck , can lift the bridge out when working on the bridge .
The lucky last pic of the main deck, I had trouble getting a square length od dowel out of the keel was to large lifting up the deck, was happy indeed, I now can finish off the bow section upper deck and top deck, plan to wire in led lighting , on a big high ., Tony from down underComment
