Looking forward to seeing this one in the "water" Richard. All heading in the right direction.
An American Spy Ship?
RichardComment
Hi,
I have done a bit more to the base. Firstly I added height by gluing two pieces of compressed foam board and shoring the sides with black mounting board strips about 1mm or 2mm higher than the two boards. This will be filled in with wall plaster and a wave pattern sculpted on while it's still wet.
But before that I wrapped the masking shape of the ships hull with clingwrap and placed it in position before plastering.
I used the tiny spoon shaped back end of my paint stirrer to create the swells and waves. I removed the mask when the plaster dried and tried the ship on it. Fit was perfect. While the plaster does its final cure I will add more waves created by the ship as well as the stern section. I will seal it with a coat of varnish and paint it.
Just waiting for my chores to finish before the next phase.
RichardComment
Oh yes!! All heading in the right direction Richard. Bring on the paint and your magic hairy stickComment
RichardComment
Looking excellent Richard. I've enjoyed following all the progress.
How about finishing the seascape on this thread. Then posting just one picture of the end result on here as a sort of 'Taster'.
......then give us the Full Monty over in Dioramas 'Completed'? I would hope that might be an amicable solution. :thumb2:
RonComment
