An American Spy Ship?
....but I would ease off about deletions and being sent to a corner though.Comment
RichardComment
RichardComment
RichardComment
All right, here's an update on the base. Basically painted a coat of Future to seal the plaster from absorbing too much paint...
I normally don't mask the sides as can just paint over with gloss black. Anyway I had extra tape and time on my hands. You will notice I have not built up the wakes at the bow and froth build up at the stern before painting as I couldn't distinguish from the similar tone of the plaster used so I decided to paint first.
I used Tamiya JN Green and Gunze Blue applying the JN Green first and then randomly spraying the blue in splotches. The remainder blue mix was added Tamiya White and dry brushed over the tips of the waves. I then coated with varnish to seal in the paint. I will use pure white to pick out a few caps of the waves after sculpting the wakes.
This is quite controlled scale and calm seas and unlike what I did for my 1/72 scaled S Boat...I had to use a soldering iron tool to carve the wave swells on the polystyrene foam and then coat with plaster. not as dramatic as I wanted but now knowing that cotton wool can be used for the bow waves I might just re-visit this build and construct it.
RichardComment
Hi, this is the part that will be challenging...adding the code letters to the Oxford's bow.
It isn't very big but one of these will fit the scale and I will need to cut them to make a masking stencil. If the cut out is successful it will be used for both the black and white colors. The black drop shadow will be sprayed on first then the white over it shifted slightly to the left and above. If you think this is small...at the stern it's repeated smaller. This I may paint with a brush.
I just found out that Greg was also serving aboard two Frigates. The USS Knox and USS Clifton Sprague being the XO on the Sprague.
RichardComment
I have paused on the stenciling until I get nice and calm. Meanwhile I remembered I got some artist gesso when I was in Sydney last year. Using a stiff brush I applied it on the seascape and built up some wakes. The Oxford wasn't a speedboat so as it chugged along it created a pattern that most slow sea vessels make...
Still needs some white caps and froth...
There are some gaps that I need to plug up but that will come when I am done with the ship code letters and weathering.
RichardComment
HI Richard your ship is lookin very real an in this scale its wondrous that you have made it look so very well done an how big are the penant no.'s ? an the seascape is brillant to my knowelege i dont think ive ever done a seascape thought about it but thats as far as i got
chrisComment
