1/250 Rms Titanic
  • peterairfix
    • Jul 2012
    • 11075
    1/250 Rms Titanic
    Yes it's another titanic but this time I am working without proper instructions so I will using all my knowledge from previous builds and some of the plans I have lying around the basic kit is the old hachette part work hence the inaccuracies.
    But here's the work so far the basic structure has been finished and I am starting on the well deck wallsClick image for larger version
ID:	1140484Click image for larger version
ID:	1140482Click image for larger version
ID:	1140483Click image for larger version
ID:	1140485Click image for larger version
ID:	1140486Click image for larger version
ID:	1140487Click image for larger version
ID:	1140488Click image for larger version
  • peterairfix
    • Jul 2012
    • 11075
    Next up is concentrating on the stern adding more walls before adding the first layer of decking and then I can start on the first layer of planking Click image for larger version
ID:	1140590Click image for larger version
ID:	1140591Click image for larger version
    • peterairfix
      • Jul 2012
      • 11075
      Slight change of plans as I have now finished the planking and started on the second layer which will have the portholes in.
      But as I have now found 100 magazines from a certain online auction site but it came with a complete finished Hull and I must say a lot better than I could ever do so do I carry on or use the new Hull as I have enough parts to do both but if I can get Olympic name plates done that's what I will be doing. Click image for larger version
ID:	1141565Click image for larger version
ID:	1141566Click image for larger version
ID:	1141567Click image for larger version
ID:	1141568Click image for larger version
ID:	1141569Click image for larger version
ID:	1141570Click image for larger version
ID:	1141571Click image for larger version
ID:	1141572Click image for larger version
      • Steve Jones
        • 6615
        Wow! Totally missed this one Peter. You certainly have a real challenge ahead of you. Coming along really well. Most impressed
        • peterairfix
          • Jul 2012
          • 11075
          Not much time to post anything at the moment but here's an update I have finished the planking and the second layer I have got color on and started on promonade deck walls.
          I have been toying with the idea of lighting up the lower Hull. Click image for larger version
ID:	1141994Click image for larger version
ID:	1141995Click image for larger version
ID:	1141996Click image for larger version
ID:	1141997Click image for larger version
ID:	1141998Click image for larger version
ID:	1141999Click image for larger version
ID:	1142000Click image for larger version
ID:	1142001Click image for larger version
            • 18906
            Lots of work in that Peter, and it shows. She’s coming together very nicely..
              • 18906
              Just had a thought, have you heard of Violet Jessup? Interesting story if you haven’t.
              • adt70hk
                • Sep 2019
                • 10409
                Amazing work.
                ATB.
                • peterairfix
                  • Jul 2012
                  • 11075
                  Yes I believe she was on the Olympic when it hit hms hawke and survived titanic and britannic sinkings
                    • 18906
                    That’s the one, it all happened in about three years. She spent the next thirty years continuing as a steward on liners. I don’t know about you Peter, but I think I would have found a land job These days she could probably make a fortune by making White Star pay her to stay off its liners....
                    • peterairfix
                      • Jul 2012
                      • 11075
                      More work done this time around I have all walls on promonade deck finished and decorations in place.
                      I have the last four deck pieces fitted that now forms the boat deck and I have started on the boat deck buildings. Click image for larger version
ID:	1142146Click image for larger version
ID:	1142147Click image for larger version
ID:	1142148Click image for larger version
ID:	1142149Click image for larger version
ID:	1142150Click image for larger version
ID:	1142151Click image for larger version
                      • peterairfix
                        • Jul 2012
                        • 11075
                        Today I am starting on the wheel House and I will be replacing the wood and card original kit one with PE replacement and also I have enough spares that I can have a compass and wheel inside as well. Click image for larger version
ID:	1142284Click image for larger version
ID:	1142285Click image for larger version
ID:	1142286Click image for larger version
                        • peterairfix
                          • Jul 2012
                          • 11075
                          As this is going to Rms Olympic it a slightly easier build as it eliminates the front third covered promenade deck but here's how it looks like nowClick image for larger version
ID:	1142768Click image for larger version
ID:	1142769Click image for larger version
ID:	1142770Click image for larger version
ID:	1142771Click image for larger version
                          • spanner570
                            • 15402
                            Very nice work Peter.
                            She's looking good.
                            • peterairfix
                              • Jul 2012
                              • 11075
                              Just had a dive into all my metal parts and pulled out all that needs to be painted black. Click image for larger version
ID:	1142785Click image for larger version
