HMS DREADNOUGHT 1906
    • 15686
    Hi Carl
    I think you're enjoying this :smiling2:
    It is looking good, nice neat work. You seem to have mastered the fiddly bits.
    • Defiant911
      • Feb 2020
      • 640
      #137
      Originally posted by Jim R
      Hi Carl
      Thanks Jim, Bit of a strain on the eyes mind and you only have to breath too hard and something bends-lol. Not sure Ive mastered it but long as I don’t try to rush then it seems to go ok.
      • spanner570
        • 15391
        #138
        Excellent, steady progress and coming together nicely, Carl.
        • JR
          • May 2015
          • 18273
          #139
          Think you have mastered it Carl, and well at that.
          Regardless of the first colour for the hull I thought it had been really well painted.
          Love the timber decking, looking fwd to seeing more .
          • Defiant911
            • Feb 2020
            • 640
            #140
            Cheers John
            • Defiant911
              • Feb 2020
              • 640
              #141
              I have not progressed as much as I’d have liked with the ship as I seem to go one step forward and two back.
              However, my current issue is with fixing the rigging lines.
              There must be an easier method than I’m currently trying as it’s very much hit and miss and by this I mean more miss than hit.
              I have been using super glue to glue either end and sometimes after a few seconds it sticks and I let the easy line go and it’s fine. However, more often it springs off having not stuck and usually sticks to something else or else the end goes hard and it’s even more difficult to glue there after. Initially I drilled small holes to try and poke the rigging into but this has also not proved very successful. It’s a very frustrating task and I can’t help thinking there must be a more reliable method to approach this so any help is great fully appreciated.
              • boatman
                • Nov 2018
                • 14455
                • christopher
                • NORFOLK UK
                #142
                HI Carl dont know if this is much help to you as i build in a bigger scale but to attche rigging wires i use some tiny wire trace with a loop on one end they are about 2mm so glue wire to the 0 part of the trace an the loop it over the yardarm
                  Carl,
                  I use an accelerator, or 'kicker' for CA in those cases. A drop of CA applied to the anchor point, and a drop of accelerator on the rigging end ( or vice versa ), they bond instantly on touch. It's a tricky procedure, you need steady hands! I bought my accelerator in a spray can, but decant a little into a tin lid & apply by dipping, or paintbrush - you have to be quick, as it evaporates speedily...................
                  • Defiant911
                    • Feb 2020
                    • 640
                    #144
                    I’d like to see a picture of this if you have a close up image?
                    • Defiant911
                      • Feb 2020
                      • 640
                      #145
                      Carl,
                      Yeah, I could give this a try, I think I have some in may garage somewhere. Yes I do unless it goes off, it’s a few years old
                      • scottie3158
                        • 14201
                        • Holbeach
                        #146
                        Carl,
                        Looking good. The wooden decking looks great.
                        • Defiant911
                          • Feb 2020
                          • 640
                          #147
                          Carl,
                          Ah yes, that method works great Dave, just tried one line and it stuck instantly. Good tip
                          • Defiant911
                            • Feb 2020
                            • 640
                            #148
                            Th
                            Carl,
                            Thanks Scottie,
                            In hind site the only thing to remember which is probably pretty obvious if I bothered to think about it is that because you are adding about 0.23mm in thickness to your deck you need to keep that in mind when structures fit on top of it. With such delicate parts even very small amount can cause real
                            Headaches when you find the legs holding the platform are just a touch short meaning either it’s sits too low or else wonky. Ultimately where any decks are involved it would of been better to fit the deck around the existing parts rather than sit the deck on top. Something for me to consider should I use it again for the next ship.
                            • spanner570
                              • 15391
                              #149
                              Carl, another quick tip.
                              If the rigging line doesn't adhere first go, nip off the end before trying again. For some reason trying to stick the original end a second time makes the job harder and doesn't always work.....
                              .....I don't know either. :upside:
                              • Defiant911
                                • Feb 2020
                                • 640
                                #150
                                Yep, I’ve found that out the hard way. It’s like the dry superglue won’t adhere to the wet superglue. Who knew..
