HMS DREADNOUGHT 1906
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    #151
    Rigging sounds fun, not. Bet get some CA accelerator!
      Bob,
      get some in a bottle - it's much easier to use than a spray can!
        • 18901
        ....and don’t get debonder by mistake :tongue-out3:
        • Steve Jones
          • 6615
          #154
          Stunning work Carl. Beautiful attention to detail. Looking forward to seeing the next update
          • Defiant911
            • Feb 2020
            • 640
            #155
            Thanks Steve,
            lve not had much time and when I do put in half hour or so it seems like I make the smallest progress. everything's so fiddly.
            Carl
            • Defiant911
              • Feb 2020
              • 640
              #156
              One of the little steam powered barges put together with a little Eduard cabin bit and a little sailer stood next to it..
              Also a quick shot of the super structure to show that there is some progress. Some of it looks like it was put together by a 6 year old but as usual there are many things to learn to do better for next time.
ID:	1143871Click image for larger version
              And one of the big guns:-
                • 18901
                That looks great Carl. Really nice job. It looks suitably busy and etch has lifted it considerably.
                • Defiant911
                  • Feb 2020
                  • 640
                  #158
                  Thanks Tim, it’s coming along but it gets quite repetitive in places so I have been rather taking my time.
                  • BattleshipBob
                    • 6792
                    • Bob
                    • Cardiff
                    #159
                    Coming along very well!
                    Can i ask a ? Did the wooden deck cause any issues fitting the superstruture, and how did you glue it in place, i am worried about glue marks etc on the deck where it meets the superstructure??
                    Thanks bob
                    • Defiant911
                      • Feb 2020
                      • 640
                      #160
                      Thanks bob
                      Hi Bob, the wood deck itself is self adhesive and caused no issues.
                      the wood deck has all the holes in it for placement of super structure and other parts. The main deck has a rsised lip to which the super structure fits. rather Than stick to the wood itself I was using this raised edge to glue to. this seems to have worked ok. Of course as thin as the wood is it has raised the super structure by about 0.24mm which did cause me a few issues with little tower structures as in affect there legs were slightly short. In hind site it might of been easier long term to trim the wood around the plastic parts but this seemed like a lot of work and a higher potential of damaging the delicate wood deck.
                      you can always make new structure legs using some copper pipe or similar and just make them a touch longer so with some thought this might have made the fit easier.
                      That said, I mostly got away with it although a few areas are probably not as level as they should be.
                      As I say, as long as you take into account the small additional thickness then you can adapt certain parts as you go.
                      • BattleshipBob
                        • 6792
                        • Bob
                        • Cardiff
                        #161
                        Cheers Carl, appreciated
                        Will start KGV in the near future. Bought a wooden deck so all new too me as well. Trying to get PE set but hard to find unless you want to pay a lot!
                        • Defiant911
                          • Feb 2020
                          • 640
                          #162
                          I find a lot of the pe is just too small or delicate to use. I think the biggest improvement with pe is the railings which you can buy cheaper in 1:350 to most ships.
                          • BattleshipBob
                            • 6792
                            • Bob
                            • Cardiff
                            #163
                            Got railings which inc the cranes, agree with small pesky parts, do my head in lol
                              • 15679
                              Hi Carl
                              Looking great. PE does add quite a bit. Well done.
                                • 18266
                                Coming along nicely.
