HMS DREADNOUGHT 1906
  • spanner570
    • 15389
    #166
    Nice progress Carl.
    A good while ago, my one attempt at P.E. railings ended up in the bin as I could never, no matter what I tried, get the railings running straight and true. They looked awful and just not good enough.
    • Defiant911
      • Feb 2020
      • 640
      #167
      Nice progress Carl.
      The key is not to look too
      Closely and definitely no Macro shots..
      • boatman
        • Nov 2018
        • 14453
        • christopher
        • NORFOLK UK
        #168
        LOOKS really good Carl this will look wonderfull when finished
        CHRIS
        • Defiant911
          • Feb 2020
          • 640
          #169
          A bit of rigging on the main mask
          • JR
            • May 2015
            • 18273
            #170
            Wow that rigging is brill Carl, you must be pleased.
            • spanner570
              • 15389
              #171
              Excellent!
                • 18901
                Looks great...nice complex array.
                • Defiant911
                  • Feb 2020
                  • 640
                  #173
                  Yes, it’s not gone too bad. I just have to watch my gorilla like arms from breaking other parts whilst doing it. Plenty more rigging to do mind and then a bunch of repetitive deck bits to finish and then place main guns. I’m on the home run now.
                  • Defiant911
                    • Feb 2020
                    • 640
                    #174
                    Does anyone know what the measurement of a chain link in mm’s would be for 1:350 scale ships. I have several chains but can’t decide which looks the correct scale.
                      I reckon about 1.5 to 2mm should be about right. Most warships use studded chain
Name:	studded anchor chain.jpg
                      It prevents kinking & fouling & adds weight - it's a lot more expensive than normal chain!
                      • Defiant911
                        • Feb 2020
                        • 640
                        #176
                        [ATTACH=CONFIG]n1144834[/ATTACH]
                        Thanks Dave, I have a few chains in my box which vary slightly in size so I’ll use the closest match and try to blacken it slightly with the MIG etch burnishing fluid.
                        • scottie3158
                          • 14201
                          • Holbeach
                          #177
                          Carl,
                          Lovely work on the rigging.
                          • Defiant911
                            • Feb 2020
                            • 640
                            #178
                            Carl,
                            Thanks.
                            • Defiant911
                              • Feb 2020
                              • 640
                              #179
                              I’ve decided to fit the many coal grates which there are roughly 58 in total over the deck. Because I fitted the wood deck that additional thickness meant these sank a little too deep into the deck holes. As luck would have it the wood deck also come with its own set of etched coal grates so I basically fitted the original 58 first as a packer and then fitted the 58 more to bring the grates to the correct level, give or take. So a tedious task was twice as tedious.
                              All part of the fun of shop building.
                              Some of them will need some grey paint touching up.
                                • 18901
                                Tedious but necessary Carl.
