HMS DREADNOUGHT 1906
    • 18903
    Two choices here...
    UK leading online shop supplying hundreds of highly detailed model scenic products and scale scenery
    • BattleshipBob
      • 6792
      • Bob
      • Cardiff
      #32
      Cheers Tim :thumb2:
      Can see a right old tangle
      • Steve-the-Duck
        • Jul 2020
        • 1731
        • Chris
        • Medway Towns
        #33
        Ah, the mighty Dreadnought - one of the causes of The Great War
        Now, I'm a pre-Dreadnought man, myself, but I do have two attempts at the 1/700 card kit - with the intention of doing the trials version with all the extra QF guns atop the turrets - I'll be interested in your EZ line results...
        But as you were mentioning French ships earlier, Combrig do the Hoche and Dupuy de Lome in 1/350 resin kits - pricey though
        And if you want REAL steampunk, the latter ship must be seen to be believed...
          • 18266
          My only tip regarding the EZ line type rigging threads is to wear some form of "surgical glue" If you have the slightest rough skin on your fingers it snags and catches like mad.
          I gave up and now use (mostly) thin fly tying thread. Its smooth, no fray and looks ok. However you need to be very careful when tensioning as it has ZERO stretch. Bent yardarms and masts are very easy to make!
            • 18903
            I find it easier to handle with tweezers Ian.
            • Defiant911
              • Feb 2020
              • 640
              #36
              Some interesting models on the Combig website.
              Combrig Models - Scale model ship manufacturer
              • spanner570
                • 15401
                #37
                Poor Carl, he's going to start getting nightmares about the rigging way before he has to tackle the bl***y stuff!
                  • 18903
                  Nothing to have nightmares about is there Ron? Like all tasks, work methodically, think before you act and don’t rush. Work bottom to top and inside to out so you don’t have to reach inside finished work to fit newer lines. Lastly, when you get stressed by it (you will) rest a while and do something less exacting. Come back to it when you’re ready. It will go by faster and better than you think.
                  • Defiant911
                    • Feb 2020
                    • 640
                    #39
                    Lol, I didn’t read the instructions properly when I did that bit of railing so did the outside rail first and then struggled to do the inside. Learned two valuable lessons which as you said is work inside to outside and even more importantly read the instructions properly.
                    • spanner570
                      • 15401
                      #40
                      Nah, piece of cake! In the miles of rigging I've done, (Full size and models) not once did I get stressed.
                      Yours,
                      Pinocchio (anyone want a carrot?!)
                      • BattleshipBob
                        • 6792
                        • Bob
                        • Cardiff
                        #41
                        Yours,
                        Pants on fire sir
                        • Defiant911
                          • Feb 2020
                          • 640
                          #42
                          I e sprayed my hull, Tamiya XF-9 Hull Red which according to the instructions is the correct colour. However, it’s very much more bergundy/brown looking to me. I’ve seen other models on line, some clearly painted in the same colour and others a more more red colour. Does anyone know what the actual colour would ha e been?Click image for larger version
                          • BattleshipBob
                            • 6792
                            • Bob
                            • Cardiff
                            #43
                            I think its generally red/brown ish
                            On modelships in the KGV section its being discussed
                              • 18903
                              Hi Carl. It would be anti fouling red, a red lead colour. I agree that the hull red looks a little too brown.
                                • 18903
                                KGV was probably dark grey, the same as HMS Hood at the time of her sinking.
