Carl i think you have fitted it right as i think this is a strenghtening gusset to help support the platform as i have fitted loads of these on my ships
HMS DREADNOUGHT 1906
I hope I'm wrong, but shouldn't the right angle on the bracket be flush with the edge of the platform slot, so it abuts the mast when the platform is glued to it?Comment
As was mentioned there is no definitive colour but something between not too brown and not too red is probably more accurate. Either way, that’s what I’m sticking with now.
I can see this project is not gonna be plain sailing..Comment
chrisComment
That makes sense I guess. It’s easy enough to pull off with such small contact surface. I’ll move it tomorrow.Comment
Sorry Carl, I should have stayed shtum like wot Chris did.
Glad to read it can be easily removed.Comment
I sprayed up the grey part of the hull and dry fixed the wood just to get a feel of how it may be.
Sadly the hull
Red has seeped through onto my black pin stripe which I suspected would happen as I probably loaded the red a bit too much. So will have to remask and carefull build up the pin stripe black again..
Deck looks good Carl, does not look proud?
Feel your pain, trying to find a article about stopping bleed, if i find it i will post it. I think it said to spray over the tape first??Comment
I think decks will be fine, there quite thin and I don’t think it will
Be noticeableComment
Carl are you usein tamyia maskin tape as i find thats very good but when you are fittin the tape on an over the small rideges on the hull i find you must use a very thin instrement or like me my finger nail to push the tape in each sides of the ridge an that will stop over spill hope this helps
chrisComment
