HMS DREADNOUGHT 1906
  • Defiant911
    • Feb 2020
    • 640
    #121
    That’s looking really good Carl. Worth the effort so far....
    If I’m honest the wood decking felt a bit like I’m cheating but if nothing else I wanted to try it.
    the next level of decks could be a trial as there are many very small legs which are easily Brocken .
    • BattleshipBob
      • 6792
      • Bob
      • Cardiff
      #122
      Looks better than if it was painted, in my humble terrible painter opinion lol
        • 15687
        Hi Carl
        That looks great. I like wood decks. I know some don't but the couple of times I have used them I have been more than happy.
        • Defiant911
          • Feb 2020
          • 640
          #124
          Definitely a lot less work.
          • boatman
            • Nov 2018
            • 14456
            • christopher
            • NORFOLK UK
            #125
            Carl this is just fab
            chris
            • Defiant911
              • Feb 2020
              • 640
              #126
              chris
              Thanks Chris.
                • 18901
                It’s not cheating Carl.....it’s no different to using pre coloured etch instrument panels on a wingy build.
                • adt70hk
                  • Sep 2019
                  • 10409
                  #128
                  Great work Carl. Just had a catch up. It's coming along very nicely indeed.
                  Keep up the good work.
                  ATB.
                  • spanner570
                    • 15391
                    #129
                    .......whether folks like these decks or not, the application is neat and tidy, Carl.
                    Ron
                    • Defiant911
                      • Feb 2020
                      • 640
                      #130
                      A small update, I’ve been mainly painting a few bits (mostly grey or grey).
                      Started adding details to the main deck whilst starting on the super structure. It’s a slow process that requires steady hands and patience. To some extent im
                      Following the instructions but having fitted some of the finer detail I just know I’m going to bend or break a few before the build is done. In hind site all the main deck bits should be left to the very end of the build.
                      Ive had a few small fit issues, some of which were caused just by adding photo etch ladders which caused fit problems.
                      there’s a lot to be said for continually dry fitting assemblies before glueing.
                      As always it’s a learning curve but im
                      Making progress.
ID:	1142875Click image for larger version
                      • BattleshipBob
                        • 6792
                        • Bob
                        • Cardiff
                        #131
                        Coming on well Carl! How did you work out the correct thickness for the rigging? Looked on John's shop and theres a few to choose from?
                        Bob
                        • Defiant911
                          • Feb 2020
                          • 640
                          #132
                          Bob
                          Hi Bob, I blindly went with the advert which says it’s for 1:350 ships So I’m hoping it is. I’ve never actually calculated what diameter it should be as a check. It looks pretty thin though At 0.121mm. (X350 = 42.35mm diameter )
                          • boatman
                            • Nov 2018
                            • 14456
                            • christopher
                            • NORFOLK UK
                            #133
                            Comin on great Carl i love battle ships an yours looks great amount of detail with the wooden deck
                            chris
                              • 18901
                              This is becoming suitably busy Carl. Love the detail.
                              • Defiant911
                                • Feb 2020
                                • 640
                                #135
                                And the bits get even smaller..
