1/72 HMS Victory Cross Section
  • spanner570
    • 15389
    #91
    Nice, tidy work, Jim.
    453 and myself will be requesting you join the 'Thick Old Joiners Club' before you can say "Claw Hammer" - Well, 'Joiner's Club', anyway. :thumb2:
    • adt70hk
      • Sep 2019
      • 10406
      #92
      Simply great work.
      ATB.
        • 18901
        Fantastic progress Jim. Are you going to have a matelot in there to give it context when you finish?
        • boatman
          • Nov 2018
          • 14453
          • christopher
          • NORFOLK UK
          #94
          YEA Tim that would really set the build off great work Jim
          chris
            • 15679
            Ron - one thing I'll never be is a joiner. Even putting up a shelf is stretching my abilities
            Andrew - thanks for your support.
            Tim and Chris - not thought of that but what a good idea. Where would I get appropriate 1/72 figures. Had a quick look and a company called Hat seems to have some. Any suggestions :smiling2:
            • boatman
              • Nov 2018
              • 14453
              • christopher
              • NORFOLK UK
              #96
              JIM look on a model railway site or a company called DAPOL i think it is as ive bought their figures an they are very good plenty of detail as i turned them in to sailors on my norfolk an they look ok in my opinion an you get a good bag full an they in OO or HO SCALE
              CHRIS
              chris
                • 18901
                These might be more appropriate Jim.
                Of course, there are other sellers out there.....and I would read up on this site
                to see if they are what you want.
                  • 15679
                  Hi all
                  Firstly a couple of purchases. As Tim and Chris suggested a figure or two would add to the finished model so I bought these. I'll only use two or three, just to give a sense of scale and context.
                  HMS Victory had copper plates on the hull below the waterline to prevent ship worm, barnacles, weed etc damaging the hull. The kit does not include these plates so I bought these.
                  Not sure what glue to use but they'll have to be fitted soon as the model will have to be turned upsidedown to fit them and the further on I get the more difficult that will be. Fiddly bits may drop off! :rolling:
                  The centre section of the orlop deck was fitted along with the gratings.
                  I put together the upper section of the pump well. Construction was the same as the hold section. Main difference from the hold is that the orlop deck pump well and the bulwarks are painted white. Pure white seemed a bit harsh so white was mixed with ivory. I added missing detail to the door as I had on the hold section.
                  Thanks once again for your support. It certainly keeps the mojo up.
                    • 18901
                    Looking very good Jim. Hope the figures live up to expectations as well.
                    • scottie3158
                      • 14201
                      • Holbeach
                      #100
                      Jim,
                      My apologies for not keeping up with this fine build. Just had a good catch up. Lovely neat work mate.
                      • Steve Brodie
                        • Sep 2014
                        • 4652
                        #101
                        Thats looking Bloody stunning !
                          • 15679
                          Thanks guys for your posts
                          The next job was to fit the rider tops and the knees under the deck beam supports. A notch had to be cut from the knees to allow them to fit correctly.
                          Then all painted white.
                          The knees were fitted first. The blue foam is just to hold them in place while the glue dries.
                          The rider tops fit above the riders in the hold. The left and right ones are different heights.
                          The front rider top fits over a grating and leaves a tiny gap. I filled this with a small off cut of wood.
                          Stay safe, we'll soon all be jabbed :tongue-out3:
                            • 15679
                            Hi all
                            Sorry for such a long gap between updates. Better weather and a list of jobs from "the boss" means less bench time.
                            The next job was the beams for the lower gun deck.
                            All painted off white.
                            Most are fitted but some will fit later after the pump columns go in.
                            The lower gun deck bulwarks were lined and the gun ports framed. The last plank had to be notched to fit around the deck beam supports.
                            There was an odd gap. Not sure if it was my fault or the kit's but easily filled with a scrap of wood.
                            Stay safe folks and model on :thumb2:
                            • scottie3158
                              • 14201
                              • Holbeach
                              #104
                              Hi all
                              [ATTACH=CONFIG]n1146712[/ATTACH]
                              [ATTACH=CONFIG]n1146713[/ATTACH]
                              [ATTACH=CONFIG]n1146714[/ATTACH]
                              [ATTACH=CONFIG]n1146715[/ATTACH]
                              [ATTACH=CONFIG]n1146717[/ATTACH]
                              [ATTACH=CONFIG]n1146718[/ATTACH]
                              [ATTACH=CONFIG]n1146716[/ATTACH]
                              Jim,
                              Liking this a lot.
                              • adt70hk
                                • Sep 2019
                                • 10406
                                #105
                                Lovely, very good indeed.
                                ATB.
