Revell 1/96 Spanish Galleon
  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #106
    OH them frontal shots look great an its very nice work Andy very well done an its great to see you fitting in lights really brings the model to life in my opion great work
    chris
    • Bobby Conkers
      • Jan 2020
      • 529
      #107
      So the next problem I've given myself is to fit lights in the crow's nests while keeping it secret.
      Sadly, my 'first' solution, feeding wires inside the masts themselves will not work, the hollow is just too narrow. So, for my next solution I'm going to 'fake' conduits using straws, feed the wiring through and try and make them look like secondary masts/mast supports of some kind. Not at all authentic but it's my bloody ship and I'll do what I want.
      If it ends up looking rubbish I'll bin the lights.
      [ATTACH]439807[/ATTACH]
      • adt70hk
        • Sep 2019
        • 10439
        #108
        Coming on very nicely indeed. Very well done.
        • rtfoe
          • 9123
          #109
          Looking good Andy but why lights in the crows nest...the lookout has a pension for reading novels at night does he? :smiling2: If the straw doesn't work, thin strand of wire minus the insulation stuck on either side of the pole may still light up the tiny bulb.
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #110
            WELL :thinking:Richard they dint have lights in the crows nest as far as i know but all ships have a white lights called running or steaming lights up on their masts but on a galleon im not sure but you cant deniy the look out a good ole read if he gets bored can you lol:rolling::smiling5::smiling5::smiling5: an Andy WHY not just glue tiny 1/2mm wires up the mast to the bulb an stick the wires to the mast as in my opinion a drink straw fixed to the mast will look out of place but thats how i would do it if it was me
            chris
            • Bobby Conkers
              • Jan 2020
              • 529
              #111
              OK, so, with a bit of tidying still to do, this is what I managed.
              [ATTACH]439843[/ATTACH]
              I think this is the best I could do with this solution, and it isn't terrible once touched up and straightened, but perhaps not good enough.
              Taking your ideas from above, womdering if I could perhaps 'invent' some rigging, wrap the wires in thread so they look like rope, and string them up. Might try that on the next mast and see how they look, then go back if I'm happy.
              I know there shouldn't be lights in the crow's nest, but I have no sense of authenticity - if the model looks better lit up there, in they go, but not to the detriment of the model as a whole.
              I also now have some tiny weeny drill bits which I think I may be able to use to open a couple of the hatches in the hull. TBC!
              • Bobby Conkers
                • Jan 2020
                • 529
                #112
                So, managed to get all the lighting together. Top tip for myself - set it all up inside the hull next time. As it goes, I couldn't have done that this time as I didn't have a bloody clue what I was doing.
                Revell's masts as ever were bent as a Tory PPE contract. Managed with some judicious leaving on radiators to straighten enough for rigging to sort out.
                Of course, we all know what this means: it's rigging time.
                Photo below - doesn't show it in the best light as yet, I'll try and find time to take some better ones over the next week.
                [ATTACH]440918[/ATTACH]
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #113
                  ITS looking really good Andy with the lights an brings the model to life im happy to say but should the rear mast go off at that angle ?
                  but very good work im pleased to say to you
                  chris
                  • Airborne01
                    • Mar 2021
                    • 4038
                    • Steve
                    • Essex
                    #114
                    If you have problems with the yards you may consider using wooden knitting needles mate; all diameters, perfectly straight, readily available and inexpensive to boot!
                    • adt70hk
                      • Sep 2019
                      • 10439
                      #115
                      Very, very nicely done.
                      A great effort.
                      ATB.
                      • Bobby Conkers
                        • Jan 2020
                        • 529
                        #116
                        chris
                        Thank you. A perfectly valid question - in this case yes, it's at that angle. It's the only one which went in snug into its D slot, the other two wobbled about something rotten!
                          • 18955
                          That’s so the mast can take the strain. Under load it would be pushed forward so wouldn’t look so strange.
                            • 15815
                            Hi Andy
                            Looks good with the lighting sorted.
                            • Bobby Conkers
                              • Jan 2020
                              • 529
                              #119
                              Quick update - I'm doing rigging. Slowly. Very slowly. No pictures as it still looks exactly the same.
                                • 15815
                                Hi Andy
                                Ah the pleasures of rigging a sailing ship. WW1 biplanes drive me demented and they're easy by comparison.
                                Good luck.
